A 10 Incher and a 12 Incher
Old 08-05-2010, 05:58 PM
JAKE
JAKE's Avatar
Default A 10 Incher and a 12 Incher
Many of you (maybe even MOST of you) may have observed that, when viewed from the rear, a LOT of our Vettes sit CROOKED.
Last I read, when asked, even the "Vette Guru" - what's his name anyway? - only smiled.
Anyway, both my son's 96 and mine were no exceptions. Both were noticeably HIGH on the PASSERGER SIDE - and not just visually either, but also with my long bubble level used to verify.
So to attack the problem I began playing with the bolts and I ended up having to install and adjust a 10 incher on the DRIVER'S side and a 12 incher on the PASSENGER SIDE. Both are 1/2" diameter.
I bought the bolts at Home Depot and, no, I didn't get all **** about Grade 8 and drilling holes for cotter pins. Those who choose to do so; be my guest. Double nutting and/or self-locking nuts are options. More than one way to skin a cat.
BTW, the 10" bolts, often seen offered in the aftermarket kits, would not have work for me. Passenger sides needed 12 inchers.
Not only did this bring the back end level - both visually and with the afore-mention bubble level (LOL) but I was, at the same time, able to lower the rear to get rid of that awful "Butt High" look.
Man, did that mod make the cars look SO MUCH MORE SLEEK.
Just thought I'd pass this along for the benefit of those who've yet to play that game. Now you guys can have fun dissecting what I did; I'll just it back and enjoy the show, LOL
Jake
Old 08-05-2010, 06:10 PM
PLRX
PLRX's Avatar
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Jake, I had that problem and when I installed the VBP's mponospring I lowered the passenger side an extra inch and now it's leveled.
Old 08-05-2010, 06:20 PM
jon0108
jon0108's Avatar
same here. I just bought a brand new NOS rear spring thinking that would solve it, but it didnt
Old 08-05-2010, 08:36 PM
BADDUCK
BADDUCK's Avatar
Location: One day you're a Comet...the next day you're dust... Arkansas
Damn, I thought this was gonna be about a **** flick.
Old 08-05-2010, 08:45 PM
383vett
383vett's Avatar
Received 1,544 Likes on 1,044 Posts
12 inches, I'm impressed.
Old 08-05-2010, 08:48 PM
C4vettrn
C4vettrn's Avatar
Where are these adjustment bolts your refering to? Are they on the front/rear spring or both? I have my motor out and figure this would be the time to play with the suspension or do you need the weight of the engine to level it correctly?
Old 08-05-2010, 08:55 PM
BADDUCK
BADDUCK's Avatar
rear
jimmers
jimmers's Avatar
Old 08-05-2010, 09:07 PM
ch@0s
ch@0s's Avatar
Originally Posted by jimmers
mee too can I have my click back ?...
Old 08-05-2010, 09:15 PM
JAKE
JAKE's Avatar
ROFL!!!!
Jake
socalman
socalman's Avatar
St. Jude Donor '10
This is commonly known as fatassitis. The passenger side isn't up, the undue stress on the drivers side...........
Old 08-05-2010, 09:29 PM
PLRX
PLRX's Avatar
2017 C4 of Year
Old 08-05-2010, 11:44 PM
GREGGPENN
GREGGPENN's Avatar
C4 of Year Winner (appearance mods) 2019
Yep, that's part of it. I've seen/read about that before. It's more pronounced for 200lb people.
I also wonder if passenger side springs are set a bit higher to compensate for the fact the road is not level. Roads are crowned for rain roll-off. If you set things level on your drive, the passenger side would sit low on a road.
Old 08-05-2010, 11:54 PM
COPO
COPO's Avatar
You thought of **** when you read 10 AND 12 incher
Old 08-06-2010, 12:18 AM
PLRX
PLRX's Avatar
2017 C4 of Year
Old 08-06-2010, 12:27 AM
Otis S.
Otis S.'s Avatar
That's what she said. I'm sorry I had to.
To keep this on topic my car is level. But if I have this problem I will know how to fix it.
Old 08-06-2010, 04:17 AM
JAKE
JAKE's Avatar
Some are much more noticable than others. Measure the gaps between the top of the tire and the lowest part of the wheel molding (both sides) for any difference. I prefer mine equal, not more gap on one side than the other.
Jake
To A 10 Incher and a 12 Incher
Old 08-06-2010, 08:36 AM
PDQUIK95
PDQUIK95's Avatar
Location: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
Jake,
I have almost an 1 1/4" offset with longer bolts on mine to get it to set level on DS/PS.This is a common problem on a lot of the late model C4s. Spring changes and bushing didn't help it.The frame just appears to sag and take a set after a while with constant drivers side weight.Most seem to always end up having the drivers side lower than the PS. I plan a future 5 point roll bar to help keep the frame straight and also stiffen it.
Rick
Old 08-06-2010, 08:37 AM
mike100
mike100's Avatar
I have a longer bolt on one side too, but I never wanted to mention it because I though I might get flamed (not the gay type of flame-you flamers,lol).
springs fatigue though- seems like on every older car I ever had, the passenger side was an inch lower.
Old 08-06-2010, 09:05 AM
BADDUCK
BADDUCK's Avatar
Sure it takes those to make a **** film for straight guys. Or maybe you have a different frame of reference .....like 3 and 4 inchers.
Quick Reply: A 10 Incher and a 12 Incher
