OBD-I vs: OBD-II
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Hi all, and sorry to resurrect this thread but I'm curious about this. The 1994 and 1995 models both used a PCM, and I'm wondering, is what you say about the '95 model also true for the '94? If not, do you know of the major differences?
I hope to really never have a OBD2 code which would make me real happy.
The same code scanner that works on my 1997 chev pu also works on my 95 corvette. It will communicate with the car as to codes or engine information. The plug is the same. I can scan the engine functions and recieve trouble codes on it, both the code and a brief description.
This scanner also works with my 05 Ford pu. I don't know a whole lot about obd1 or obd11, but I do know this actron scanner works on my car.
Thank you all for the replies. So here's my next question, if the setup for OBD II was technically "there" in the '94-'95 models, could switching to a true OBD II PCM really be as simple as getting a PCM from a '96, then getting a calibration flashed (say from '96 again) and installing it in the vehicle?
The 1996 OBDII PCM monitors the crank position and rear o2 sensors. These could be tuned out, but I really see no reason to run an OBDII PCM in a 94/95. I'm not sure but the PCM and CCM may also have issues communicating.
Thanks for the info! I was just thinking about the "true" OBD II and was wondering if it would offer any perks as far as drivability and easier diagnostics.
http://www.amazon.com/Automotive-Dia.../dp/0760328005
This is a good book that describes the difference between OBD-I and OBD-II systems and gives great advice in the use of code reader and scan tools. I learned quite a bit about the function of emissions systems and how to troublrshoot and repair them from this publication.
Well after your input I think I may just skip the project I had in mind and save some dollars in the process. Thank you, and also thanks for the link to the book as well, I may have to pick that up.
