84 crossfire won't start when it's hot
I did it during the daylight so it was hard to see.
I tried it before letting the car warm up so I could see what it was suppose to do. Then I let it get to the point where it would not restart and tested again. One injector appeared to be getting no signal at all and the other was real dim. Couldn't really tell if it was blinking or not.
First, if you are not using an led test light, you won't see the injector pulses well
84's have TBI correct. I would be checking those injectors for resistance first while warm. (since warm is where your issue is) Unplug a bad injector and attempt restart.
BUT... we did have the same exact problem as you with the vehicle suddenly cutting out and it turned out the ignition coil was cracked. Car would die sometimes, and not restart for a few minutes.
Our no hot start ended up being the multec injectors. ('89)
So, theoretically, you could have a coil cutting out, causing the car to stall, and one of the injectors (2 correct) could be causing the ecm to not fire either injector causing the no restart.
Also, isn't 13 psi a little low? How's the fuel filter, new? Easy and cheap diagnosis plus good preventive maintenance.
How do you test for resistance?
I have a new filter and sock on the pump. I am not sure if 13psi is too low or not. I was hoping somebody here could tell me.
Is there anyway to test the ignition coil?
The test light I'm using is in a noid light test kit I got from the local auto store. When I tried it before letting the engine warm up, it blinked bright.
I'm totally on a limb here, but I believe you check those injectors the same way you do any other injector. pull the harness off the injector, and put an ohm meter between the contacts and see what it reads. Or multecs should read in the mid teens, but on ours, half read under 6 ohms. With the bad ones disconnected the ECM would fire the good ones.
You only have a 50/50 chance, so if you don't have an ohm meter, the next time it shuts down, unplug one injector and see if the car wants to start. (running on 4 cylinders of course)
Anybody know where to look next?
I have no idea what to try next.
Anybody?
I really don't want to pay the stealership an outragious amount just to tell me they can't find a problem.
Is there a way to test the ECM?
What would make the injectors not fire but still have fire to the plugs?
Any other places on the internet I can look?
Come on you all. I did all the test you asked, don't leave me hanging.
If you don't have a clue, say so.
If you have suggestions, please let me know.
Tom400CFI, you were a great help early on, where are you now?
