Thermo and fan temps ??
Is there an ideal cooling setup for the mild street 383ci setup? What I mean is I am going to install a EWP and was thinking of changing (lowering) the on-off temp for my fan controls i.e 190* on-175* off. Should the thermostat open when fans kick on? What are you 383 guys with under 450hp running for fan temps and thermostats and how is it working?
Location: One day you're a Comet...the next day you're dust... Arkansas
160* stat is OK if you run only in hot weather or race the car. For year around including cold weather I think a 180* stat with 210* on and 195* off will work better.
Chevy V8 engine was designed for 180*F operating temps. EPA requirements caused that temp to increase. If not special reason to use a higher temp T-stat, go with 180*. 200-205*F turn ON temps: 190-195"F turn OFF temps. You can put a 160"F stat in the engine, but it will have NO EFFECT other than to slow the engine's warm-up time to final operating temp.
