need help with gauge cluster
i just purchased a 85 vette and im having trouble with my gauge cluster, only the turn signal will work, i took the cluster apart and it looks clean and the bulbs are fine. i looked at the wiring cluster under the dash and it is a mess. there is a aftermarket box, spliced wires and unconnected wires.
any suggestions would be appreciated
also looking for any wire diagrams that would also be wonderful
for some reason i cannot post attachments
Heres a link page for repair of you dash. http://www.batee.com/corvette/dcrg/index.shtml
You have to link pics from a hosting site to your post in order to "attach" photos.
Worst case by a used dash harness off of EBAY. It should at least have all the proper connectors on it. What kind of aftermarket device is attached? Are you talking about the ECM Computer?
Woody
Woody
possibly it says mirage 6000 on the box, all the loose wires are coming off of that.
how far can you strip the dash out? right now i have the top of the dash off and the pad, how much further can i remove it to see the wires easier?
