Rubber bushings
Rubber bushings
Are there any manufacturers that sell plain old rubber bushings for the rear suspension of '92-'96's. I do not like poly at all, and I find rod-ends are way to harsh for street use.
Sure, you can get rubber sway bar end links. Rubber bushing rear control arms, but you have to buy the entire control arm. Corvette Recycling has some. And I'd say you could get rubber for the rear sway bar. Not sure on the bushings in the batwing.
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
There may be others that can help.
But for now poly is the most reasonably priced and is not all that harsh.
Properly inflated tires and good shocks are a more determining factor.
Anyways its a Corvette, not a Cadillac.
Drive it like you stole it!
The one good thing about the poly is like with the end links. You don't have to press them in with a press like you would with rubber bushings. So, easier to install.
