modify the STEALTH RAM INTAKE to fit the c-4 vettes
Old 03-20-2002, 04:55 PM
grumpyvette
grumpyvette's Avatar
Default modify the STEALTH RAM INTAKE to fit the c-4 vettes
As you may or may not know the TPI intakes don,t flow much air above 4500rpm so HOLLEY just came out with the STEALTH RAM INTAKE that flows WAY MORE AIR AND MAKES WAY MORE HP but its too tall to fit the L98 engine c-4 vettes by about 1" and most of the camaros, well I found a place with the knowledge and skill to modify the plenum on
the STEALTH RAM INTAKE to fit the c-4 vettes and do other custom EFI intake mods http://fuelinjectorclinic.com/
this company does quite simular work to other brand intakes all the time! they can also make EFI intakes from the HOLLEY BBC intakes, or make EFI INTAKEs from the EDELBROCK SUPER VICTOR intakes http://www.holley.com/HiOctn/ProdLi.../AMSM/5955.html http://www.holley.com/HiOctn/ProdLi.../AMSM/5951.html
send one of the HOLLEY EFI TUNNEL RAM BASES to these people and they can adapt the parts necessary to make what you want.
[Modified by grumpyvette, 10:08 PM 3/20/2002]
Old 03-20-2002, 05:01 PM
-=Jeff=-
-=Jeff=-'s Avatar
Default Re: modify the STEALTH RAM INTAKE to fit the c-4 vettes (grumpyvette)
the STEALTH RAM INTAKE to fit the c-4 vettes http://fuelinjectorclinic.com/
do you have any more info on this.. because that website has NONE
I am curious about this intake.. I am running the Miniram but want to see how well the Stealth Ram works
Old 03-20-2002, 05:05 PM
MrJay
MrJay's Avatar
Wonder how much it will cost to have it done?
Grumyvette are you having them do your intake or are you doing it your self or are you going with a different hood.
Jay
Old 03-20-2002, 05:12 PM
grumpyvette
Default Re: modify the STEALTH RAM INTAKE to fit the c-4 vettes (MrJay)
the guys name is frank CALL HIM, HE DOES QUITE SIMILAR work on other brand intakes all the time. and makes custom adapter too.1 -954-421-7003
Old 03-20-2002, 05:21 PM
Jim85IROC
Jim85IROC's Avatar
Grumpy, did you test-fit the stealth ram without the throttle body? I recall that a guy on thirdgen.org with a custom setup built a wedge-type spacer to go between his throttle body and plenum, and it gave him the necessary clearance by tilting the throttle body down. Other than bolt issues, it seems like a good solution without making major modifications to the plenum.
Old 03-20-2002, 05:29 PM
WINNER
WINNER's Avatar
Cruise-In II Veteran
Jay
Inquiring minds want to know :lol: :lol: :lol:
Old 03-20-2002, 10:06 PM
Bill Reid
Bill Reid's Avatar
Default Re: modify the STEALTH RAM INTAKE to fit the c-4 vettes (WINNER)
I just emailed this topic to myself so I can easily keep track of the updates... I am EXTREMELY interested in the final results (including prices) :yesnod:
Old 03-21-2002, 05:50 AM
Sharky Guam
Sharky Guam's Avatar
Default Re: modify the STEALTH RAM INTAKE to fit the c-4 vettes (billreid1@***.net)
Keep us posted! :cheers:
Old 08-05-2004, 10:57 AM
aklim
aklim's Avatar
Received 2,240 Likes on 1,947 Posts
I know I am dredging up the dead but just as an FYI, I talked to Frank and it is about $400 and he supplies you with a sheet metal plenum that will work. I don't understand how but he will send me pics. His # is 561- 427- 0082. Will post more results when they are advailable.
Old 08-05-2004, 12:01 PM
mos90
mos90's Avatar
the miniram has a 3" runner, the stealth ram has a 6" runner. with the 6 inch 6" runner compared to the 3, you will make peak hp and tq about 500-700 rpm's less then the miniram. you will sacrifice some peak hp with the steath but you will make torque much lower in you rmp range. i think the stealth ram would be best suited for a stock lower end that will not hold up to the high revs the miniram likes or someone who like a lower torque curve. but for a solid forged lower end (even a 350ci) that can turn 6500- 7000 rpm's, the miniram will outperform.
i think the minram peak hp #'s are made at 6500 rpms, and the stealth is 5600 rpms
personally i really dont feel the need for a lot of low end torque. i like mine for mid to high for hook up purposes. but thats my preference and maybe not someone elses.
Old 08-05-2004, 12:57 PM
scorp508
scorp508's Avatar
Wow this is an old thread. First grumpy says the guy will modify the base and now another person who talke to the same guy said he'll send you a sheet metal intake? Ummmmm did I read that right?
Old 08-05-2004, 01:52 PM
SloRvette
SloRvette's Avatar
Cruise-In VII Veteran
I'm pretty sure this guy is the guy that Grumpy originally got together with to do the new plenums. He ended up shutting Grumpy out and then Grumpy doing his own ones. I believe this is the folded sheetmetal one. I don't think either one is a real good idea. Hopefully in the next 6 weeks I'll have my 398 with a full SteathRam together.
Old 08-05-2004, 02:46 PM
aklim
aklim's Avatar
What are you using for a hood?
Old 08-05-2004, 02:47 PM
aklim
aklim's Avatar
AFAIK, Grumpy and Frank said they both use different plenums. The base remains the same while the plenum changes. Grumpy is trying to get someone to cast it and Frank said he has some sheetmetal ones made up. I don't have pics of either yet.
Old 08-05-2004, 03:10 PM
montie98
montie98's Avatar
Is it possible that modding the Stealth Ram will affect its original performance? I mean I cant belive that Holley wont just make one for us C4 guys.Who buys more aftermarket performance parts than us?
Old 08-05-2004, 03:19 PM
SloRvette
SloRvette's Avatar
Stock hood with a Harwood cowl induction scoop bonded on. I'll snap pictures as I go.
Old 08-05-2004, 06:12 PM
Wheelman
Wheelman's Avatar
Prove to me that the modifications that you make to the stealthram do not affect its driveabilty/power range/flow from that of the original and I will be interested
To modify the STEALTH RAM INTAKE to fit the c-4 vettes
Old 08-05-2004, 06:40 PM
loiq
loiq's Avatar
Alright! Here we go!
Old 08-05-2004, 06:53 PM
Blown Vette
Blown Vette's Avatar
Are you offering a money back guarantee? I would suggest a written one for anyone considering this.
A few people I have spoken to have major problems during your last go around. Do all cylinders burn evenly? Does the throttle body still hit the hood?
Old 08-05-2004, 06:56 PM
vetster86
vetster86's Avatar
Holley just came out with the stealth ram intake? Gee I think its been around a few years now.
Quick Reply: modify the STEALTH RAM INTAKE to fit the c-4 vettes
