1992 C4 climate control question
Old 06-08-2010, 12:57 PM
mundo
mundo's Avatar
Default 1992 C4 climate control question
The person I bought the car from didn't provide an owners manual.
Can climate control be shut off and the AC and heater be operated manually? I suspect my AC is on all the time. If it can how so?
ALSO:
How do you program a radio station. In my C5, pick the station, hold the desired button for 3 seconds.
This one a 'set' button. I tried it the C5 way but didn't work. Can I get some help?
Old 06-08-2010, 01:14 PM
94z07fx3
94z07fx3's Avatar
If you have RPO C68 electronic climate control then to operate it manually just select the fan speed, the temp, and the vents you want to use. The "AUTO" light should go out when you make your own selection.
Tune the radio to the station you want, press set, the set light should come on, press the number button that you want to set for that station. To set the time turn the radio off, press the set button, the set light should come on, press the tune up and down buttons to change the minutes and hours.
Old 06-08-2010, 04:10 PM
ks5shooter
Support Corvetteforum!
ks5shooter's Avatar
St. Jude Donor '10-'11-'12-'13
To 1992 C4 climate control question
Quick Reply: 1992 C4 climate control question
