Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-04-2010, 06:11 PM   #41
ch@0s
CF Senior Member
Support Corvetteforum!
ch@0s's Avatar
Quote:
Originally Posted by Quickvette84 View Post
Well I have it installed now, I have to still clean it up but here is a pic of it in the car
Click the image to open in full size.
Looks awesome great job.
ch@0s is offline   Reply With Quote
Old 06-04-2010, 09:25 PM   #42
BrianCunningham
CF Senior Member
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
sharp looking
so, you going to make a run of parts for the older C4 guys?
BrianCunningham is offline   Reply With Quote
Old 06-04-2010, 10:48 PM   #43
69427
69427's Avatar
Location: I tend to be leery of any guy who doesn't own either a chainsaw or a handgun.
Looks great, man!
69427 is offline   Reply With Quote
Old 06-05-2010, 01:08 AM   #44
5abivt
CF Senior Member
5abivt's Avatar
That looks good. Would have looked better without the c4 emblem in the middle though.
5abivt is offline   Reply With Quote
Old 06-05-2010, 01:18 AM   #45
pologreen1
CF Senior Member
pologreen1's Avatar
Well here is a pic of the gauge pod after engraving the corvette emblem on a CNC mill at my work, still have some wet sanding and polishing to do. I went with 3.5" for speedo and tach and 2 1/6" for rest of gauges, blue LED for high beam and green LED's for turn signals really clean look. Should be installed in the car by this weekend.
Have considered making templates for this?
It seems like there is a lot of interest, and like you do quality work.
pologreen1 is offline   Reply With Quote
Old 06-05-2010, 05:36 AM   #46
Black89Z51
Suckin' gas, haulin' ass.
This is what I did a few weeks ago:
I am going to try and find away to adapt the sending unit for the trans temp gauge to my ZF.
Also, the Oil pressure gauge is pegged because I hadn't added the correct sending unit yet.
Black89Z51 is offline   Reply With Quote
Old 06-15-2010, 10:27 PM   #47
klug932000
Junior Member
klug932000's Avatar
do you have the plans on your computer on how you did your wiring for the new gauges
klug932000 is offline   Reply With Quote
Old 09-09-2010, 10:31 AM   #48
v8vette84
CF Senior Member
v8vette84's Avatar
I know this thread is a little old but can you but JUST the dash panel without the gauges? It doesn't seem like it, i haven't found one yet. Anybody seen one? I don't want to gauges too, just the panel...
v8vette84 is offline   Reply With Quote
Old 09-09-2010, 06:08 PM   #49
mattwalker87
CF Senior Member
mattwalker87's Avatar
call and email vettaid 100 times a day. thats what i did till he sold me one. heres my setup.
mattwalker87 is offline   Reply With Quote
Old 09-10-2010, 12:37 AM   #50
v8vette84
CF Senior Member
v8vette84's Avatar
How much did he charge you for it?
Old 09-11-2010, 12:22 AM   #51
856SPEED
CF Senior Member
856SPEED's Avatar
Here's mine installed....
http://forums.corvetteforum.com/pict...ictureid=57060
having problems at low speeds with it though.....speedometer wants to jump around at speeds below 45-50mph......hi beam light is extremely bright.....light for the water temperature does not work......Jody from Vett Aid has been very good about responding to these issues, though......seems like a class act......
__________________
85 Vette with many modifications: ZF6, TPIS/AFR alum. heads, TPIS LT's, TPIS ZZ9 roller cam, TPIS 52 mm throttle body, RT hi-flow cat., miniram, 355 ci. rebuilt engine, 3.73 gears; air pump delete, "1990 ZR1style" rear fascia w/admiral blue GS stripe, custom wheels, chassis dyno tuned by TPIS
856SPEED is offline   Reply With Quote
Old 09-15-2010, 06:38 PM   #52
v8vette84
CF Senior Member
v8vette84's Avatar
Old 09-15-2010, 06:42 PM   #53
mattwalker87
CF Senior Member
somewhere around 80-100 bucks i think. its been a while. ..
Old 09-15-2010, 06:52 PM   #54
v8vette84
CF Senior Member
v8vette84's Avatar
ok thanks
Old 09-15-2010, 11:10 PM   #55
USAsOnlyWay
CF Senior Member
USAsOnlyWay's Avatar
So what do you lose with this?
Ave MPG, Inst MPG, yes.
Cruise control?
Odometer... that seems very problematic.
Anything else?
Looks damn good though!
USAsOnlyWay is offline   Reply With Quote
Old 09-16-2010, 12:08 AM   #56
mattwalker87
CF Senior Member
Quote:
Originally Posted by USAsOnlyWay View Post
So what do you loose with this?
Cruise control?
Anything else?
since its a ground up rebuild, ls1 swap im not worried about mpg, avg, cruise, or even odometer.
Old 09-16-2010, 01:59 AM   #57
USAsOnlyWay
CF Senior Member
Wish I was there with you, haha.
Old 09-16-2010, 04:04 PM   #58
USAsOnlyWay
CF Senior Member
What does the rocker switch do?
Old 09-16-2010, 06:18 PM   #59
mattwalker87
CF Senior Member
me? the smaller one on the top left by headlights is the foglight switch. the one to the right where the info cluster was(actually theres 2 side by side and a gauge over there) is for the front air ride.
Old 09-17-2010, 10:36 PM   #60
Vintagevetter
CF Senior Member
Vintagevetter's Avatar
I like the idea of analog gauges. The instrument panels in the C4's..especially the later models...was a BIG step backwards in my opinion.
However..what I would like to see...is someone offer a analog conversion for the C4 panel...using C5 or C6 instrument in place of the after market type instruments. I think it would look more like...stock from the factory...plus having a more finished look. As anyone tried this idea?
Vintagevetter is offline   Reply With Quote
Reload this Page Custom built C4 analog gauge cluster
Tags
1990, anolog, autometer, c4, cluster, clusters, corvette, custom, face, gauages, gauge, gauges, l98, phantom, vettaid, white, zr1
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
