Late model engine management, coil per cylinder and electronic throttle for LT1 and 9
The May/June issue of Street Thunder magazine has an article on adapting coil per cylinder, LS2 engine management and electronic throttle to LT1's, LT4's and L98's. It shows greater horsepower and torque across all RPM's. As a bonus for LT1's and LT4's you get to do away with the troublesome Optispark forever. Every engine gets the benefits of a single coil per cylinder and the increased computing power of the LS2 engine management system. A company called EFI Connection in concert with TPIS developed and sells the system. The internet address for EFI is:
eficonnection.com.
I don't know the price of the system and I don't have any relations with any of these companies, but I thought it might be something all of you might want to look at. If you can get a copy of the magazine they have a review of the system and of the installation, which they did on a 396ci LT1. I hope this does someone some good.
Paul
eficonnection.com.
Paul
Pro Mechanic
1. I don't know what it costs either, but I can't IMAGINE that the cost/hp is anywhere near the "sane" area.
2. The electronic throttle on my C6 sucked a big a**. And the one on my '05 CTS-V does too. I would NEVER downgrade from the mechanical throttle linkage to the highly annoying electric throttle system, unless it was PROVEN to me in advance, that it can and will "behave" just exactly like or (somehow) better than the mechanical system.
The Coil on plug certainly has it's advantages, but the rest of the system? I'm skeptical.
Coil
For those with this: http://www.youtube.com/watch?v=cccYWADbHPw
That is when the eficonnection system makes sense. You need to be at heroic power levels or it isn't justified.
I'm still running my original opti (yes, its a low mile car), although I did replace the cap and rotor once = a loose rotor helped to create carbon tracking in the cap.
Some guys will probably rant about the price, but I think we should all be glad that someone is making interesting parts for the LT1/4 engine.
Thomas
Thomas
Pro Mechanic
You can buy alot of optis for that price, or maybe even a set of the new AFR Comp heads.
And for the electronic throttle body, my C5 has one and I hate it. For me it is a real disconnect form the gas peddle to the engine.
Pro Mechanic
Yeah, I sold my 06 GT for just that reason. If it was the only car I owned or if it wasn't a 5 speed I could have probably gotten used to it, but going from it to the GS and back really screwed up my driving technique. My wife's Grand Prix has the electronic throttlebody. It has the same features that i hated on my Mustang, but its an automatic so its not unbearable.
People who say you can't tell a difference are lying to themselves. It is terrible. In my C6 I could depress the gas pedal and release it completely...before the engine RPM changed one bit. When the engine DID repsond, it was slow and lazy going up and back down. Older cable actualted engines respond like lightning by comparison. Makes rev-matched down-shifting SO much more fun and rewarding, when the engine actually does something when you jab the pedal.
Probably for normal driving and without scrutinizing it, it can pass by us with out a noticeable effect.
I'll probably do this kit when I go forced induction so I can run the LS computer.
The LS computer is FAR more advanced than the LTX computer, much faster, allows real-time tuning, etc.
But I will NOT do the electronic throttle - you can keep a mechanical throttle which to me is important, why ruin a good thing. The electronic throttle is advantageous in it's own right but not for what I use my car for.
And the idea of getting rid of the Opti is reason enough. Sure you can buy several Opti's for that price but would you really want to?
Because the LSx computer has to deal with a lot more than the LTx computer its faster, more memory and a lot more "stuff" in the box.
The 96 LTx computer is close, but just like PCs car computers become faster, more powerful each year.
The late model LTX computers are definitely good, but they are 16 bit.
The LS computer is 32 bit, which basically means it's exponentially more powerful.
I forget the number exactly but the LS computer can process millions more calculations per second than an LTX computer, which is one of the reasons you can do real-time tuning with it.
LOL - no offense taken. With all the crap people spew on the Internet it's good to make people back stuff up!
Wow, decreased throttle response for only $2000.00. Let me find my checkbook. Just wait until they get steer-by-wire developed. Mercedes is working on it and so is GM. Now that's scary. Steering wheel not attached to the wheels. Only attached to a variable resistor.
Some of the "by wire" type stuff makes sense, I see why they have done it and it makes sense to do it for a lot of reasons. It allows them to "program" the car much easier, for safety reasons and so on. They are already doing this with the electronic throttle stuff and steer-by-wire will allow them to do the same thing: "program" the steering for different ratios, driving conditions, etc
A lot of the issues with the electronic throttles isn't the throttles themselves - it's the torque management programming. They put progressive delays in there to lessen driveline shock and so on. If you turn the torque management stuff off (which you can do in the HP Tuners software for example) it feels crisper and more responsive. That being said, I'll take the mechanical throttle please.
For the "average" consumer the by wire stuff is probably the way to go, we all know they have to build/program vehicles for the lowest common denominator - but for enthusiasts and shade tree mechanics like me it means I'll probably never own a "fun" vehicle much older than a 2000 or so!
