Rough idle
Rough idle
Hi everyone
I'm trying to find a message I posted, but it's taking a while. The original message concerns two problems I was having with my '89 automatic corvette. the first is rough idle whenever the car is in gear and the second is hesitation when I'm accelerating. I've tried cleaning the trottle body...also I had a mechanic check the onboard computer and the only error message I got, was that the MAP line or port might be clogged. I don't know what this is, so if anyone can help...pleease...I don't want to hurt my babe. thanx in advance
Cruise-In V Veteran
Re: Rough idle (akisana)
Idle problems are a necessary evil of corvette ownership. Have you done a simple tune-up. Plugs, wires cap etc. One bad plug or wire can cause havoc!!!!
Have you checked your TPS (Throttle position sensor).
You can try disconecting MAF and if it runs good - it needs replaced.
I'm not exactly sure where it is located on the 91, but I think it's mounted on the rear side of the upper plenum, on the passenger side. If so, it has a 90º vacuum hose elbow that connects it's port to the vacuum port on the plenum beneath it's mount bracket.
[Modified by BBA, 11:20 PM 3/17/2002]
Re: Rough idle (BBA)
If you haven't done so yet, I'd replace all the vacuum lines and boots on a car that is 11 years old. A small leak can really mess things up. About $20 worth of hose and fittings.
