Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-17-2002, 06:11 PM   #1
rxbdwl
CF Senior Member
rxbdwl's Avatar
Default '85 heater acting weird....any ideas?
My cars been in the paint shop about all winter so I decided it needed a little excercise today. I drove about twenty miles and stopped about twenty minutes then drove another thiry and all was fine. I then stopped about an hour and a half. Then drove about thirty miles and had no heat. Blower worked fine if you count cold air. Water temp was normal. I then stopped for dinner for about another hour and a half (slooooow service) and when I headed home the heater was fine all the way (about fifty miles). I checked the water when I got home and the level is fine.
I was stumped when it quit working. Then when it started again I was totally stumped.
Any of you gurus out there have any idea what is going on?
rxbdwl is offline   Reply With Quote
Old 03-17-2002, 07:51 PM   #2
Bluevette85
CF Senior Member
Bluevette85's Avatar
Default Re: '85 heater acting weird....any ideas? (rxbdwl)
Try filling your radiator this way. Take cap off and run engine until thermostat opens. Turn heater on hot. Have a helper idle the engine about 1200-1500rpm. You should see the coolant level drop. Fill it up and replace the cap before letting off the idle. Your cooling system will now be full. This assumes that your system isn't dirty or clogged. You may want to flush it first.
Bluevette85 is offline   Reply With Quote
Old 03-18-2002, 05:50 PM   #3
rxbdwl
CF Senior Member
rxbdwl's Avatar
Default Re: '85 heater acting weird....any ideas? (Bluevette85)
Thanks Bluevette. I don't really think it's low but I'm stumped on what happened. I suppose if it was low the heater core could have kind of air locked. At any rate I'll give it a try.
Old 03-18-2002, 05:55 PM   #4
fiddleplayer
CF Senior Member
Passenger side next to the heater blower motor is a vacuum accuated valve. either the vacuum is not there, the diaphram is leaking or the valve is stuck. I usually have to move mine by hand after it has set for a while or I just tie it open with a ty-wrap.
fp
fiddleplayer is offline   Reply With Quote
Old 03-18-2002, 05:58 PM   #5
Bluevette85
CF Senior Member
It can be deceiving and look full. Mine took another 3/4 gal when I filled it this way.
Reload this Page '85 heater acting weird....any ideas?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
