Help prepping the deck for head installation.
Re: Help prepping the deck for head installation. (C4-Wolf)
Wipe the deck down with rubbing alcohol real good and let it dry. That will get all of the oil and dirt off.
Former Vendor
Re: Help prepping the deck for head installation. (KYVette90)
I used a puddy knife and then a very fine sanding block (gently) to get the mineral deposits off from around the cooling holes. actually my dad did it, he has done fine polishing of powder metal tooling were .0001" is critical, therefore I was not worried. Its cleaned them really good. I then took acetone and wiped everything very well. Just make sure when you rub your hands across the surfaces, there are no high/low spots from deposits or gaskets. It needs to be VERY clean. Good luck
