Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-10-2010, 11:10 AM   #1
jakers
CF Senior Member
St. Jude Donor '06
jakers's Avatar
Default Engine has been sitting 14 months. Has not turned over... Pre-Oil Question?
March 2009 -Take the car for a 200 mile trip. Discovered the rear hubs were shot. Bought parts and equipment to do R&R of rear suspension. The project grew to include drive train. Replacing universal joints, poly-bushings, clutch slave cylinder, hydraulics, beam plates and possibly a new flywheel. BTW, this is all Black Harley Man's fault! Working with limited time and limited budget. The car is still on the Race Ramps/Jack(Front) and Jack stands (Rear). Yes, I do miss driving the car!
May 2010 - The good news is I am back and focused on completing the jobs at hand. Dana 44 is back in the car with new bushings. Universal joints/half shafts, rear knuckles, and hubs are done. Brakes put on the car yesterday! I also installed the proper pilot bearing to be used with the MN6. (Note, that the rental tool from Advanced Autoparts worked like a charm. I had previously tried the packed grease method and that was a complete failure and only created a mess to clean up.)
As I get closer to getting this car back on the road after 14 months I am pondering the start up of the car. I am assuming that every drop of oil has had time to find its way back into the engine oil pan.
Q. Should I place a small amount of oil into each cylinders through the spark plug holes before restarting a engine?
Q. If so, how should I go about it?
Q. How much oil should be placed in each cylinder?
Q. Best Method for getting it into the cylinder etc?
Thanks!
jakers is offline   Reply With Quote
Old 05-10-2010, 11:22 AM   #2
cuisinartvette
CF Senior Member
St. Jude Donor '05
Make sure the battery is charged and fire it up.
cuisinartvette is offline   Reply With Quote
Old 05-10-2010, 11:24 AM   #3
Pete K
CF Senior Member
Pete K's Avatar
I would be more worried about the stale fuel.
Pete K is offline   Reply With Quote
Old 05-10-2010, 11:26 AM   #4
mr.beachcomber
CF Senior Member
mr.beachcomber's Avatar
Yikes! Fourteen months is a long time to allow an engine to sit, but I think that you're on the right track. First start with fresh, clean oil and filter change. Then remove all the spark plugs, squirt some oil into each combustion chamber, and turn the engine over by hand using the dampener bolt at least two complete revolutions to make sure that the rings were free in all eight cylinders.
Next I would align #1 cylinder at TDC, remove the distributor and use a pre-oiling device attached to a power tool to spin the oil pump to pre-lube the system. Keep spinning the oil pump until you see coming out of the rockers on each bank. Re-install the distributor.
Use some starting fluid on the air intake housing and start up the engine. Check your oil pressure, water temperature, and RPM. Keep the engine running until it reaches operating temperature. You should be good to go then after re-setting/checking the initial advance. Good luck!
mr.beachcomber is offline   Reply With Quote
Old 05-10-2010, 03:02 PM   #5
TAZO
Junior Member
TAZO's Avatar
My experience. I tore off the rear suspension on April of 2006. It has been sitting on jack stands for the last four years with no money or time to get her fixed. I started working on her a few weeks ago. I charged the battery checked oil and fluids. I then turned the key and she fired right up. Not bad for a 19 year old car.
TAZO is offline   Reply With Quote
Old 05-10-2010, 03:16 PM   #6
AGENT 86
CF Senior Member
AGENT 86's Avatar
Pull injector fuses, crank until good oil pressure is achieved, install fuses and fire her up.
AGENT 86 is offline   Reply With Quote
Old 05-10-2010, 03:21 PM   #7
Steve85
CF Senior Member
Cruise-In V Veteran
Steve85's Avatar
Quote:
Very surprised. Last december the snowblower gas was about 2 yrs old and didn't even smell like gas anymore.
Steve85 is offline   Reply With Quote
Old 05-10-2010, 03:54 PM   #8
TAZO
Junior Member
TAZO's Avatar
Quote:
I put some stabil fuel in her when I stored it. I was very suprised too. I was expecting it not to turn over. Someone upstairs was watching over her.
Old 05-10-2010, 03:56 PM   #9
MK 82
CF Senior Member
MK 82's Avatar
It's an LT1 so your oiling method won't work. Starting fluid is entirely unecessary.
Just start it!
Eddie
MK 82 is offline   Reply With Quote
Old 05-10-2010, 04:10 PM   #10
Churchkey
CF Senior Member
Churchkey's Avatar
Quote:
& add: Let it run 20-30 minutes then change oil & filter.
Good luck.
Churchkey is offline   Reply With Quote
Old 05-10-2010, 05:26 PM   #11
PLRX
1995 and 1996 Vettes
St. Jude Donor '09-'10-'11-'12-'13
Support Corvetteforum!
PLRX's Avatar
Your Vette is ruined, give it to me now.
PLRX is offline   Reply With Quote
Old 05-10-2010, 05:41 PM   #12
tblt44
CF Senior Member
tblt44's Avatar
After an oil change.
You may also want to drain the fuel tank
If you put some fuel stabilizer in you should be Ok
tblt44 is offline   Reply With Quote
Old 05-10-2010, 06:24 PM   #13
Cruisinfanatic
CF Senior Member
Cruisinfanatic's Avatar
it would take another month for me to do all that.
Probably for the most part all unnecessary.
Cruisinfanatic is offline   Reply With Quote
Old 05-10-2010, 07:21 PM   #14
LD85
CF Senior Member
LD85's Avatar
Send a message via Yahoo to LD85
What Agent86 said, and drain the old fuel,,, mine sat for that long and the car would crank and not fire,, fuel was bad
LD85 is online now   Reply With Quote
Old 05-10-2010, 07:53 PM   #15
MK 82
CF Senior Member
MK 82's Avatar
I think you should jack up the radiator cap and put a new car under it!
GEEZ!!
Old 05-10-2010, 08:00 PM   #16
cuisinartvette
CF Senior Member
St. Jude Donor '05
The second it fires up it will get more oil quicker than preoiling. Ive started cars up that sat for yrs with no problems. THere is still oil on the parts in your engine but its up to you.
Old 05-10-2010, 08:02 PM   #17
Mrs. glass car
CF Senior Member
Mrs. glass car's Avatar
Quote:
That is just what I would do. Fire it up and run until warm, then change oil.
I have let cars sit for years and started with a fresh battery. Also I have never had a problem with gas sitting in a closed tank for several years either.
Mrs. glass car is offline   Reply With Quote
Old 05-10-2010, 08:08 PM   #18
Bondami
CF Senior Member
Bondami's Avatar
Im from the just start it camp.. but as to the fuel.. If you have trouble starting it or running poorly, its the gas. I dont know what they have changed in fuel formulations but it goes bad quickly.
Bondami is offline   Reply With Quote
Old 05-10-2010, 08:15 PM   #19
the blur
CF Senior Member
the blur's Avatar
just start it and drive it.
Ever see cars in the dealer parking lot sit for a year. you think they worry about it.
the blur is offline   Reply With Quote
Old 05-10-2010, 10:59 PM   #20
Mark85Vett
CF Senior Member
Mark85Vett's Avatar
Quote:
Anything older than 3 or 4 months with the newer fuel is junk, even with stabilizer in it...for the sake of $50 in questionable fuel, it's a small investment to start fresh and not have to worry.
Mark85Vett is offline   Reply With Quote
Reload this Page Engine has been sitting 14 months. Has not turned over... Pre-Oil Question?
Tags
car, corvett, corvette, engin, engine, lt1, months, prelube, preoiler, restarting, rotation, sitting, start, tool, turned
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
