1987 alternator wiring
Old 05-11-2010, 03:06 AM
red87corvette
3rd Gear
red87corvette's Avatar
Default 1987 alternator wiring
I did an engine swap on a 1987 corvette. The crate motor was turn key and came with a 3 wire alternator. On the original cs130 alternator, it has wires on the "s", "F", and "L" slots. I have two post (besides the batery line) on the new alternator. Any ideas on how to wire it?
Old 05-11-2010, 05:36 AM
94z07fx3
94z07fx3's Avatar
Does the new alt look like this?
Old 05-11-2010, 10:48 AM
red87corvette
3rd Gear
Thaks for your reply!
Yes it looks like that. It claims it's a 1 wire alternator, but it does have the #1 and #2 slots. Your diagram shows a ground on the right side. I dont have that.
Old 05-11-2010, 03:26 PM
AGENT 86
AGENT 86's Avatar
The pic is showing that the case is grounded, there is no terminal.
You state in first post, it is a 3 wire alt, and now it's a one wire alt ??
Google, "how to wire a one wire alternator", that should help you.
Old 05-11-2010, 09:05 PM
red87corvette
3rd Gear
According to the manufacturer, the alternator can be used as a 1 wire alternator. It also has slot #1 and #2 so it can be used as a 3wire. The alternator is the same as your diagram. I would like to use the original wires that went to the original alternator and wire it as a 3 wire. I want to prevent low rpm charge problems and would like the dummy light and voltage gauge to work. Can I wire the original wires from the harness to the #1 and #2 slots? If so, witch one goes where?
Sorry about the confusion.
Thanks again for your reply
Old 05-11-2010, 09:27 PM
AGENT 86
AGENT 86's Avatar
I think you should contact the maker, and find out what terminal is what. On my 86, #1 is the field wire and #2 is the sensing wire. Not sure if 87 uses the same alt, but chances are the configuration is the same.
http://dankai.shawwebspace.ca/asset/...ing_system.pdf
To 1987 alternator wiring
Quick Reply: 1987 alternator wiring
