Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-08-2010, 05:48 PM   #1
bigjohn85
CF Senior Member
Send a message via ICQ to bigjohn85
Default How does the 4+3 Manual Transmission Overdrive work?
I was looking to buy a late 80's corvette with a manual transmission and a seller was telling me that the button isn't in the stick anymore and when he is easy on the car it automatically goes into overdrive and when you are hard on it, it stays in the regular gears. Is this how the transmission suppose to work?
bigjohn85 is offline   Reply With Quote
Old 05-08-2010, 09:36 PM   #2
rodj
CF Senior Member
rodj's Avatar
Sort of.
The O/d is on every time you turn the key on.
When the right conditions are met ( varies by year ) , speed / engine temp /TPS volts; the O/d will automatically engage.It will also kick out back to direct drive when certain conditions are met ( hard accel, etc)
See
http://www.5speeds.com/43table.htm
The O/d can be turned off by using the button and then manually engaged when ever you want to
rodj is offline   Reply With Quote
Old 05-12-2010, 01:18 PM   #3
bigjohn85
CF Senior Member
thanks for the help. Makes a lot more sense now. do you suggest the six speed? I could just go up to a 89.
Old 05-12-2010, 01:32 PM   #4
CAJUN C4
CF Senior Member
CAJUN C4's Avatar
Quote:
6 Speed,89'...Definatly. The early C4 4+3's were not very durable.If you , can..go with at least an 89' and get the ZF 6 Speed.
CAJUN C4 is offline   Reply With Quote
Old 05-12-2010, 01:52 PM   #5
techvette
CF Senior Member
techvette's Avatar
IMO, the 4+3's are fun to play with, but once the novelty wears off and the overdrive unit quits working you will wish you had the (more durable) 6-speed.
techvette is offline   Reply With Quote
Old 05-12-2010, 07:48 PM   #6
rodj
CF Senior Member
rodj's Avatar
Quote:
Originally Posted by Driver84 View Post
IMO, the 4+3's are fun to play with, but once the novelty wears off.
Some owners disagree
http://forums.corvetteforum.com/c4-g...-all-time.html
Old 05-12-2010, 11:14 PM   #7
FOURSPEEDVETTE
CF Senior Member
FOURSPEEDVETTE's Avatar
In my early 1985 the O/D is never on automatically when the key is turned on. You must engage or disengage the O/D with a switch on the console. Later on the switch was mounted on top of the gearshifter. Otherwise it's just a T10 4 speed transmission. You can use O/D in 2nd 3rd or 4th gear. Just a note that the early 4+3 transmissions were very durable. Just not many people ever really knew how to use them and wound up damaging them through misuse.
FOURSPEEDVETTE is offline   Reply With Quote
Reload this Page How does the 4+3 Manual Transmission Overdrive work?
Tags
1984, 43, 85, button, c4, corvette, engaging, manual, overdrive, schematics, transmissioin, transmission, vette, work, works
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
