Won't idle below 900 rpm
Old 05-06-2010, 11:21 AM
jak112460
jak112460's Avatar
Default Won't idle below 900 rpm
I put this in another section but this seems a better place. I am helping a kid on his '85 Corvette and it won't idle below 900 rpm without stalling if he gooses the throttle or taps the throttle and lets it drop down to idle it stalls. It will fire right up. I have set the TPs and everything on that seems fine. I have not pulled off the throttle body or checked the IAC yet. Is it possible the IAC is not working properly? What else should I be looking for? Thanks.
Old 05-06-2010, 11:27 AM
DarkBlue88
DarkBlue88's Avatar
Location: Charlotte NC, behind someone going 10 under the speed limit
Any codes?
Quick Reply: Won't idle below 900 rpm
