O2 sensor
O2 sensor
Do I need to reset the computer after installing O2 sensor?
Have an 84 with CFI so I only need to install sensor.
And when you guys say reset computer your refering to disconnecting the battery right?
Thxs
Kevin
Thxs
Kevin
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
No, you don't have to clear the ECM by pulling the negative battery cable or ECM fuse for 30 seconds. Just install the sensor.
I would use a little anti-seize compound on the new sensor's threads, though, taking care not to get any on the sensor end of the unit.
