Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-09-2010, 03:24 PM   #1
dsmithh
CF Member
Support Corvetteforum!
Send a message via AIM to dsmithh Send a message via Yahoo to dsmithh
Default 1988 C4 Battery Replacement
Even after charging, my '88 battery struggles to turn over the car....looks like a new one is the plan. The battery area is on the drivers side, near where the hood closes. There is some kind of mechanism above the battery, and possibly a structural element that runs diagonally toward the center of the engine. Does all this have to come out to replace the battery, or is there a trick to doing this job?
dsmithh is offline   Reply With Quote
Old 04-09-2010, 03:51 PM   #2
RollaMo-LT4
CF Senior Member
St. Jude Donor '10-'11-'12-'13
RollaMo-LT4's Avatar
The side cover comes off, for easy battery access.
Here:
http://www.corvettemagazine.com/2001...ttery/bat1.asp
Also, a quick search turned up this thread.
http://forums.corvetteforum.com/c4-t...y-removal.html
__________________
1996 Corvette - LT4
2011 Camaro SS Convertible
2011 Harley Davidson FLHX Street Glide
RollaMo-LT4 is offline   Reply With Quote
Old 04-09-2010, 04:48 PM   #3
ggrassmid
CF Senior Member
ggrassmid's Avatar
Send a message via AIM to ggrassmid
just a few bolts to removed the quarter panel with the gills on it. 3 holding the inner finder well to the panel, 1 on top hiden by the weather stripping, and 1 on the bottom. I just take the whole panel off. Very easy once you do it the first time.
ggrassmid is offline   Reply With Quote
Old 04-09-2010, 08:47 PM   #4
jfb
CF Senior Member
If the battery is old enough to be near its guarantee period, you may be correct about it being at the end of its life, however, several other things can cause slow or no cranking. You can tell the state of charge of the battery by measuring its no load terminal voltage. 12.9 volts and higher, fully charged, 12.0 volts and lower, discharged and linear in between. During cranking, the voltage on the battery terminals must not fall below 9.0 volts or the battery cables need cleaning, battery needs charging, or the battery is at the end of its life. Try removing the battery cables (neg first) and cleaning the cable lugs, bolts, and the battery posts and replace the cables (neg last).
jfb is offline   Reply With Quote
Old 04-09-2010, 09:47 PM   #5
redrose
CF Senior Member
Quote:
the bottom bolt is invisible, but reach into the gill panel/ rocker panel seam with a 10mm open end wrench and loosen that bolt...the gill panel hole for that bolt is slotted (except on 84 MY, if not yet 'fixed')...after battery swap/gill panel reinstall, very slowly open the drivers door and ascertain door and gill panel don't argue, adjust gill panel mounting if reqd.
redrose is offline   Reply With Quote
Old 04-09-2010, 10:56 PM   #6
96_vette
CF Senior Member
96_vette's Avatar
Check the output on your alternator, should be 12-14 volts at idle. If your alternator is failing to charge the battery, it may have only enough running voltage to run the ignition system and other accessories. After you replace the battery, check your alternator by turning on your headlights and applying and releasing the brake, If your lights dim or your dash lights dim that would indicate a voltage drop. Replace alternator.
96_vette is offline   Reply With Quote
Old 04-09-2010, 11:01 PM   #7
jfb
CF Senior Member
Quote:
Originally Posted by 96_vette View Post
Check the output on your alternator, should be 12-14 volts at idle. If your alternator is failing to charge the battery, it may still have enough running voltage to run the ignition system and other accessories. After you replace the battery, check your alternator by turning on your headlights and applying and releasing the brake, If your lights dim or your dash lights dim that would indicate a voltage drop. Replace alternator.
No thats not true at all! Cold, the alternator output voltage is normally 14.7 volts (dash voltmeter will read 0.3 volts lower, or 14.4 v) and as the alternator warms up to its operating temperature, the voltage drops to 13.7 volts (dash voltmeter will read 13.4 v).
Old 04-12-2010, 07:51 AM   #8
dsmithh
CF Member
Thanks for all the tips here. I was able to remove the side panel as directed, took the battery in, and was diagnosed as a bad 'cell'. What a relief. New battery and buttoned up on Saturday....starts like a champ!
Reload this Page 1988 C4 Battery Replacement
Tags
1988, 1996, battery, c4, change, corvette, output, removal, replace, replacement, voltage
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
