oil in intakerunners
Old 04-11-2010, 04:33 PM
moriise
Navigator
moriise's Avatar
Default oil in intakerunners
I have a 1996 with a 396cui Golen engine.My truble is wery sooty sparkplugs on nr 5,7,8.When i pulled off my intakmanifold it was a lot og oil in the intakrunners.I have deleted egr and pvc on the manifold so no oil comes in here.When i connect my hp tuner i can see the pcm is adding 25% fuel. What can this problem be.
Morten
NORWAY
Old 04-11-2010, 06:38 PM
C4fan
C4fan's Avatar
St. Jude '10
I'm not a pro but I was reading a post with a similar problem where a blown intake gasket was discovered allowing oil to come in via the lifter valley. It seems to me it was on a 383 engine and may have been ported heads/intake leaving thinner gaskets. I can't remember the post or I would send a link. I think they talked about a way to test for the leak also. That may be something to look into but I wouldn't go taking anything apart just yet.
Old 04-11-2010, 07:02 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
You need some kind of pcv system on the car do you have them on the valve covers at least?
Old 04-11-2010, 08:54 PM
cumbercr
cumbercr's Avatar
I had the same symptoms from a bad intake gasket. The gasket was deformed around the intake port on #7 alloying oil to be ingested from the lifter galley. It also caused a vacuum leak that was read by the O2 sensor as a lean condition.
Old 04-12-2010, 07:44 AM
mseven
mseven's Avatar
MO, the oil could be blow by from unseated rings, or bad gasket sealing and the sooty plugs from lack of tuning.
To oil in intakerunners
Quick Reply: oil in intakerunners
