Where does green temp gauge wire come through firewall
I cannot find my temp gauge wire. It's solid green, not striped?
Where does it coem through the firewall. Thanks!
'86 Vette
Edit I'm searching through old threads for this info and not having any luck.
'86 Vette
Dark Green on every GM I've owned. Should be Pin D4 at the Display; C2 at the Connector (though the latter may be different for an '86). Dark Green/White should be Oil Temp.
CF guys come through again! Thanks SunCr. I found a couple of green wires which weren't connected. Per other threads I read, I grounded them and used the one that caused the readout to show 299 on the temp gauge. You guys rock!
Thanks,
Steve
Thanks,
Steve
