Picture of Back of 94-96 Driver Airbag Unit?
Awhile back I had the ignition cylinder on my '96 replaced (performed by a shop). Since then one side of the airbag module in the steering wheel protrudes slightly like it is not sitting / aligned properly within the wheel.
Anyone have a pic of the back of the module / steering wheel with the bag removed?
Also, are there any additional precautions I should take when attempting to remove the unit and re-mount it other than unhooking the battery?
Disconnect the battery, wait 10 minutes or so to insure the power has discharged from the SRS and then remove the airbag. Re-seat the airbag in the steering wheel.
All this is in the Factory Service Manual.
