84 vette Cross fire Nitrous
Need help with a crossfire injection nitrous set up!
just need a list of parts to buy. My goal is not to go entirely big just a 75 hp wet shot. here is what i got so far
edelbrock 10lb bottle
temparary engagement switch
3 toggleswitch panel
I found it is usually cheaper to find a kit that has most of what you are looking for then add bits as necessary. Not sure exactly what kits work on a crossfire, but a quick google should get some hits. You should be able to find some kits without bottles if you don't need/want to have two.
It's not like you're bolting on a 400hp plate system or something. Just keep the jets small, and if you have any questiosn, talk to NOS, Edelbrock, or whoever you're using the most parts from. They'll help you to make sure everything is set up correctly.
Like any major mod, be careful and watch things closely till you get used to it and know it works correctly.
Marc
Why?
Marc
Marc
My setup was stolen over the summer. I had everything needed to do the nitrous. but now i am kind of glad they did because my engine is slowly starting to wear away. i guess it just wasnt meant to be. but this winter im going to rebuild it and maybe have a base hp of 450 so i will not need nitrous. also changing the intake to projection FI.
I had a problem and had to leave it parked last weekend. I'm headed up there now to see if I can sort it out. The Renegade was fine, the problem was with the valve lash - possibly that the cam is going flat.
That production kit is no longer available for CFI, but you may still be able to buy the parts or cobble something together and make it work. If I remember right, there was a guy that was featured in one of the vette mags a number of years ago that ran the CFI kit in his 84 and ran like 11.4s or somethng like that with it. I just don't remember all the details anymore, but you may be able to Google it. Good luck and don't let it go lean.
It's here:
http://www.gmhightechperformance.com...tte/index.html
