pros & cons of running no thermostat
I ran without one for a month or so last winter while hunting a coolant leak. The car took forever to warm up, and going down the highway the engine wouldn't break over about 55 degrees C. The engine oil temp gauge would never come off the peg either.
I ran mine with no stat last summer (in florida heat, 90's) for something to do one day. The engine warmed up alot faster, and ran much hotter in town and on the interstate.
My guess is that the water is traveling to fast and dosen't spend enough time in the radiator to cool.
Living in a part of the country where it dosen't get so hot will surely have a different outcome.
http://www.badasscars.com/index.cfm/...rod/prd280.htm
The only times I've ran cars without the T-stat was strictly for diagnosing certain cooling system problems. My observations here in hot California weather where that the car would take noticeably longer to reach the same operating temperatures vs with the t-stat (specially from a cold start) but would still eventually reach whatever max temps the engine wanted if sitting in traffic. Once the t-stat is open it's open and no longer has control. This is why when t-stats fail in the open position one of the signs is extended warm up time not overheating. This is also the principle behind "fail safe" thermostats that are designed to fail in the open position to save the engine from overheating damage.
One thing is the thermostat also serves as is a restrictor to a point. If you don't run a thermostat, it is still recommended to run a restrictor. Both the thermostat and restrictor serve to allow the block to completely fill with coolant. That keeps the top of the engine full of coolant, which will keep it cooler.
I had a friend a long time ago port his water ports on the head gaskets to match the block. It wouldn't keep fluid full at the back of the block, and constantly ran hot. He ended up changing back to a stock type head gasket, and the problems were gone.
You'll freeze your *** off in the Cincinnati winter. One day driving in the Sierra through snow flurries the thermostat on my car (at that time a 240SX) stuck open and the heater blew nothing but cold air, more or less ambient temp since it was being drawn from the outside and had almost no warming from the heater core.
Once again. The T-stat doesn't determine the "normal" operating temperature at which the engine will operate. The radiator does. The T-stat simply determines how fast it heats up to "normal". The circle track guys don't run stats simply because it's a potential failure point. Not because the engine would run cooler. There would be no point in then installing a restrictor plate. In theromdynamic terms an orifice.
Are you guys racing (competitively) and looking for every single little thing to win? Or are you just running it on the street, strip, auto-x, track use? My point is this these threads are dumb, we debate over something so stupid. ALL street and production cars have a t-stat from the factory. Just about every engine (liquid cooled) on the planet has one. Put the darn T-stat in the car, and don't worry about it. Please stop with these ridiculous and childish threads, they are totally pointless.
Running no t-stat is bad, and dumb. Put it in and be done with it.
Race on!!!
Jim
