Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-13-2009, 08:29 PM   #1
gsff19
Junior Member
Default Engine Replacement
Here is my issue, I have a stock 1984 corvette with the L89, Im looking to put in a crate motor most likely a 350 with a carb/air cleaner. I need to know if anyone has done that and what I need to look out for.
Do I need to change any of my cooling components?
is there any hood clearance issues?
whats a good motor to use?
What extra will I have to purchase with the motor?
gsff19 is offline   Reply With Quote
Old 12-20-2009, 10:15 PM   #2
gsff19
Junior Member
Really Nobody has any advice.........
Old 12-20-2009, 10:25 PM   #3
Pete K
CF Senior Member
Pete K's Avatar
Quote:
As a newer member, you may not be aware that this is discussed very often. After years and years of archiving data, many do not wish to answer the same questions over and over.
I have not done the swap, so I cannot offer 1st hand advice.
I would recommend using the search feature to look back at all of the carb swaps done in a c4.
Good luck.
Pete K is offline   Reply With Quote
Old 12-20-2009, 10:45 PM   #4
pr0zac
CF Senior Member
pr0zac's Avatar
Send a message via AIM to pr0zac
don't carb it.
pr0zac is offline   Reply With Quote
Old 12-21-2009, 03:26 AM   #5
Frizlefrak
CF Senior Member
Frizlefrak's Avatar
As Pete mentioned, this has been discussed a multitude of times. A search of the archives should net you a great deal of data.
If you decide to remove the CFI and use a carburetor, you will need the carb and low profile intake (hood clearance is an issue), a non-computer controlled distributor (HEI), a means of lowering your fuel pressure such as a regulator, a drop down air cleaner for hood clearance, and all associated mounting brackets and linkages, cables, etc. You will need a means of locking the torque converter if Auto, such as a vacuum switch, and a bracket for the TV cable on the auto. I'm sure I'm missing something, but that should get you started. Please be advised that if you live in an emissions testing area, your car (while it may still pass) is no longer emissions legal.
It's certainly doable, and many have done it. Mind if I ask why specifically you want to switch to a carb? There are a number of ways to improve CFI performance, and the system is quite reliable if maintained like any other EFI system.
As for engines, your car has a generation 1 small block Chevy engine. There are an abundance of suitable crate motors available, depending on what your power goals are and what you want to spend. And unless the block is defective in some way, you can rebuild yours too.
Your cooling system should be fine if it's up to snuff already.
BTW...your engine is the L-83, not L-89.
Good luck in whatever you decide.
Frizlefrak is offline   Reply With Quote
Old 12-23-2009, 07:52 PM   #6
Brettmc
CF Senior Member
Brettmc's Avatar
Send a message via AIM to Brettmc Send a message via Yahoo to Brettmc
Keep your injection. You might think carbs are easier to deal with, and to a degree they are, but FI is much more accurate and not hard to understand if you study on it some.
Brettmc is offline   Reply With Quote
Old 12-23-2009, 09:04 PM   #7
larry00
CF Senior Member
larry00's Avatar
Larry Hedge
You can buy a marine engine with stand alone engine management system . EFI is better !
larry00 is offline   Reply With Quote
Reload this Page Engine Replacement
Tags
1984, 2004, c1, c3, c4, carb, corvett, corvette, engine, engines, good, louis, performance, replacement, st, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
98 engine replacement with a 2001 Z06 engine - work ok? kmcnalley C5 Tech 12 06-08-2005 11:42 PM
1982 Vette Engine Replacement Question 82VetteCA C3 Tech/Performance 14 04-06-2004 10:10 PM
Engine Replacement: What to do with the old one? Eric76 C3 Tech/Performance 16 10-03-2003 02:58 PM
Crate Engine replacement for L98 884fun C4 Tech/Performance 13 03-05-2002 04:01 PM
1990 zr1 Warranty engine replacement????? FoolCrzy C4 ZR-1 Discussion 14 03-02-2002 05:20 PM
Update: GMPP is covering my engine Replacement. 96VegasVette C4 Tech/Performance 12 11-29-2001 01:20 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
