Need some suggestions...
Hey guys, I have a 84 Crossfire. Recently my car started overheating and realized that the fan wasnt cutting on.. So I immediatley changed the relay on the firewall next to the battery.. Needless to say, still dosn't work. My question is what else could it be and if need be, should I get a replacement OEM fan or what do you think would be the most logical idea? Thanks in advance
Check the fuse. Then disconnect the fan connector and apply 12 volts to the red terminal and ground to the black. If the fan works, then get a voltmeter and start checking backwards starting at the relay.
