Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-22-2009, 11:16 AM   #1
lilredc4
CF Senior Member
lilredc4's Avatar
Default Sterring Issue
I have a 92, with no mods. I have noticed since owning the car that it has pulled to the left while driving, but has not been to bad. Recently I have noticed that it is getting worse causing you to keep constant preasure on the sterring wheel to the right to go straight. I had all four wheels aligned about eight months ago and it did not seem to help, it is like this all the time not just under braking. Any Ideas?
lilredc4 is offline   Reply With Quote
Old 11-22-2009, 11:43 AM   #2
engle1147
CF Senior Member
Support Corvetteforum!
engle1147's Avatar
Send a message via AIM to engle1147
How long have you owned the car? These car have wide wheels on all corners and tend to "track" to the level of the road. When the car pulls ensure that the roads your driving on are pretty "level". Are the tires in good shape or have they been rotated lately?
If you had it aligned the shop that did the work should have checked the related components for wear or slop....but it never hurts to double check their work.....loose jam nuts after alignment jobs are not that uncommon to find. Jack the corners up and check each position for component looseness. Other than that - your power steering rack might be showing signs of needed attention.
engle1147 is offline   Reply With Quote
Old 11-22-2009, 12:36 PM   #3
383vett
CF Senior Member
383vett's Avatar
Time for a realignment with a quality shop. Let the technician know what the car is doing. He will test drive it before and after. He should be able to adjust the camber to straighten out your ride unless you have a bad bearing, dragging brake, bad steering rack or the frame has been tweeked.
383vett is offline   Reply With Quote
Old 11-22-2009, 01:18 PM   #4
lilredc4
CF Senior Member
lilredc4's Avatar
Thanks Guy's I will check with the shop to see if something is wrong.
Old 11-22-2009, 01:28 PM   #5
jhammons01
CF Senior Member
jhammons01's Avatar
Don't overlook a hanging brake caliper.
jhammons01 is offline   Reply With Quote
Reload this Page Sterring Issue
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Why does my "98" C5 DIE ??? RODMAN1966 C5 Tech 12 08-24-2005 10:43 PM
Riding With The Top Off Revisited Redeasysport C4 General Discussion 37 06-26-2005 09:36 PM
"Z" Bashing fgordon C6 Z06 Discussion 27 06-23-2005 11:27 PM
Hey There Gang...I'm a Newbie jprez1980 C5 General 32 05-26-2005 10:24 AM
Hurst shifter installed Diamond C5 Z06 Discussion 45 09-04-2004 12:21 PM
MY C5 HAS A GHOST MITCH C5 Tech 13 08-09-2003 11:53 AM
What could cause this vibration @ 70-80mph? James94LT1 C4 Tech/Performance 21 06-19-2003 05:12 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
