Z-52 suspension??
Old 11-17-2009, 07:53 PM
RED BARON
RED BARON's Avatar
Default Z-52 suspension??
I have an 87 vert and was told by the previous owner it had a Z-51 suspension. I asked the FORUM how to verify this and you guys said check the service panel under the consol lid. I checked it and could not find any markings showing Z-51 but there was one showing Z-52. Is this a designation for the suspension in this car? The reason I'm asking is I plan to replace my rotors and I want to make sure they are the right ones. Mid-America shows different rotors for Z-51 but I don't have any idea what the differences are.
Old 11-17-2009, 08:01 PM
gbrtng
gbrtng's Avatar
Z52 is a suspension option, but I think all 87s have the same rotors. According to the Black Book the 88s with Z52 have different rotors - meaning the later style front and rear calipers. Looks like MAD has their catalog info hosed. Check with your local NAPA store first, you can probably beat MAD prices locally.
Old 11-17-2009, 08:30 PM
7SPD Z52
7SPD Z52's Avatar
Ive seen owners sell there Z52's as Z51's many times. There was even one on eBay being referenced as a 1 of 1300 car with Z51. (It was an 88 Automatic which was never made with Z51.) It is in fact back on eBay as a Z52. I think its just a common error in termonology. If it says Z52 in the console than that is what you have. Its not bad at all. It's actually suppossed to be a better controled suspension for the street. Z51 is stiffer for racing. I have an 88 with Z52 and mine has the standard 12" rotors. Th HD 13" Rotors were another J55 option all together. None the less and I could be wrong but I did think that 87 only came with one size rotor front and rear.
Old 11-17-2009, 09:25 PM
RED BARON
RED BARON's Avatar
Thanks guys, you can always get the info you need here... Been a member now 7 years and the FORUM is still the best!!
Old 11-18-2009, 06:16 PM
c4cruiser
c4cruiser's Avatar
The biggest difference between Z51 and Z52 is the springs. Z51 cars had stiffer springs. Z52 cars got slightly stiffer shocks over the base shocks and came with the base FE1 springs.
Z52 cars had slightly small sway bars than the Z51 cars. Also Z51 cars got poser steering coolers where the Z52 card did not. Both Z51 and Z52 got the quick steering rack and pinion.
All 84-87 cars had the same size rotors at 11.9" diameter in front. Because the front suspension was re-designed in '88, the front rotors had a different "hat" design than the earlier cars. The J55 13" front rotors first appeared in 88 as part of the Z51 suspension and 17" wheels.
To Z-52 suspension??
Quick Reply: Z-52 suspension??
