Early or late 93?
Early or late 93?
What is the easiest way to determine if my 93 is "Early" or "Late"? I thought I read somewhere that the serpentine belt will tell you. It is either ribbed on both sides or only one side. But which is which? And is there any other way to tell? Thanks in advance! :flag
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
Re: Early or late 93? (white93vette)
Well, let's put it this way, my '92 has the belt ribbed on both sides, so I would assume that if it was changed, it would be in the latter half of the '93 production.
Received 1,404 Likes
Re: Early or late 93? (Jim D)
well your VIN is a start
1 Post
Re: Early or late 93? (vader86)
The best way to tell is if it has the newer electronic trans. If it has a throttle pressure cable it is early. My car has all the other late stuff, but an early trans. Must have been mix and match day when mine was made. :lol:
Re: Early or late 93? (ehn84)
On mine, the production date is on a sticker inside the door jam. I believe the later models had the styrofoam bumper insert as well as the belt that is only grooved on one side. The 93 never had the electronic transmission.
well if you post it here, we can usually tell, somebody knows the whereabouts of the magic number that separates them.
Elite Torch Red Member
Well to generalize, the serial # starts at 100001 and ends at 121142, so it will help you narrow it down. Mine has a build date of July 93, and my # is 120910, so it's safe to say that mine is a late one.
Go Fast
Re: Early or late 93? (thrills)
On my 93 the belt is ribbed on both sides, my car was manufactured may 93. I know they did change to ribbed belt only on one side later.
B
B
