How Do You Diagnose a Halfshaft U-Joint Going Bad?
Old 11-11-2009, 02:40 AM
Sidney004
Sidney004's Avatar
Default How Do You Diagnose a Halfshaft U-Joint Going Bad?
A "clunking" noise developed after a track day; it coincides with wheel rotation. You can hear it in this video, ignore the static and random screeching noises, that is the camera. The noise went away on the drive home(mostly.) I put the car on jackstands and removed the wheels, everything seems tight and nothing is falling off. Put the car in gear and ran it, no noise. I think it may be the U-Joints, what should I be looking for?
http://s161.photobucket.com/albums/t...nkingNoise.flv
Old 11-11-2009, 10:37 AM
rickneworleansla
rickneworleansla's Avatar
When mine went bad I had the clicking noise while driving. I could see some extra play in the wheel when jacked up and turning the tire back and forth. It was hard to tell if it was bad visually. When I got the half shaft off it was then obvious it needed replacing. I could then see a small crack.
It's really hard to hear in the video. Jack it up and spin the wheels. You may be able to hear exactly where it is comming from. Spin the wheel a little back and forth and look for play while observing the U-Joints closely. If it has a lot of miles or track events I would change them anyway. They are fairly easy to replace. Consider it a little insurance to prevent you from needing a tow in. If it's not the U-Joints you will probably discover what is causing it in the process.
Go with the sealed spicer joints. A local drive line shop should be able to order them for you. That's where I got mine from. I think they were shipped over from Mississippi.
http://forums.corvetteforum.com/c4-t...placement.html
Old 11-11-2009, 11:09 AM
0Paul Ruggeri
Former Vendor
Paul Ruggeri's Avatar
Hey Sydney.
The trick is to twist the u-joint with your hands to see if there's any play in it. Sometimes you have to remove the half shaft to tell for sure. The joint could be dry, but not loose yet. Check the ones on the driveshaft too. I swear when we were at the track it sounded like it was in the trans.
Old 11-11-2009, 11:46 AM
Sidney004
Sidney004's Avatar
Originally Posted by Paul Ruggeri
Hey Sydney.
I hope you are wrong Paul, the car shifted normally driving back home.
Paul, I may have left the ASR switch on when we were checking it at the track, I don't remember and perhaps that noise you heard was a result of that.
Old 11-11-2009, 01:01 PM
jhammons01
jhammons01's Avatar
yeah, I hear the clunking/rattling.
When my inner half shaft u-joint took a digger, it did sound like that.
I jacked up the rear wheels and allowed them to spin in gear and looked under there, to see that u-joint flopping all around on the inside.
I've learned since then that you should have the jack stands under the suspension so that it is tucked as if the car was sitting on the ground if you are going to spin the wheels.
But in my case it didn't matter that time, the u-joint was clearly allowing the half shaft to flop around.
Old 11-11-2009, 02:05 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Put the car up in the air. Tranny is gear on in park if auto. Move a tire forward and back while under the car and see if any of the joints have any play in them. The clunk is coming from somewhere and sometimes you need to change the direction of rotation of the wheels to see where the play is. Just running the car while in the air doesn't usually tell you much unless it is really sloppy.
Old 11-12-2009, 03:22 PM
Jim McCombe
Jim McCombe's Avatar
Recently after an evening of drag racing at Infineon Raceway, my 87 developed a clunking noise from the rear which I had hoped was a faulty half shaft. I was able to drive it at home without any incidents which was just about 40 miles
It would only make the noise when I was making a sharp left turn.
After getting it up on a rack, discovered the half shafts and the U Joints were good.
Turned out to be a broken spider gear so looks like some major differential work awaits me.
Not saying yours is a faulty Spider gear but don't rule it out either.
Old 11-12-2009, 07:11 PM
M.J.L.
M.J.L.'s Avatar
St. Jude Donor '10-'11
To How Do You Diagnose a Halfshaft U-Joint Going Bad?
Quick Reply: How Do You Diagnose a Halfshaft U-Joint Going Bad?
