1994 Convertible Brake Lights
Bulbs Ok. Fuse Ok. Warning lights work (same circuit). Middle light goes on, but the four others do not go on when the brake pedal is depressed????
I've seen same problem on other cars as well as my 1984 vette I had.I would bet its the turn signal switch(bad).But thats just an edumacated guess
Had the same thing happen to mine...turn signal switch. It took me awhile to figure out since I still had the center brake light but it has a separate switch at the brake pedal.
