Suspension width: early vs. late? & Wheel clearance questions
Anyone got the width specs for 84-87 and 88-96 front and rear suspension widths from tire mounting surface to tire mounting surface?
If late offset wheels are put on early front suspension, will the tires/wheels rub at full lock?
Can late 17 X 11s be put on an early rear end without rubbing the frame/suspension/inner fender?
Will a 15” Cragar SS wheel clear the 12” disc brakes? (that question is NOT for a 15” wheel on a Vette application – its about another car with swapped in Vette suspension.
