Is there any way to make my LCD numbers darker
Old 10-03-2009, 09:36 AM
tblt44
tblt44's Avatar
Default Is there any way to make my LCD numbers darker
My LCD numbers are a really light gray color.I can only see them if I get really close.
I can't even see how fast I'm going.I cant see my MPG,my digital temp or anything unless I get right up to it and block all light.
Just wondering if there is any way to fix this without sending it out for repair?
Old 10-03-2009, 05:23 PM
pcolt94
pcolt94's Avatar
If you had a normally working system I don’t think there is an adjustment for that in the sense you want. The normal brightness control is obviously not helping you in a normal way. So with out seeing the symptom, I would assume there might be a problem. Either the display is bad, or there might be some voltage to low that is fed to it. It sounds like a global problem and not just one digit in the panel. I remember reading about a regular transistor for the panel and have seen it under the steering wheel column.
I will look thru the FSM and see if I can come up with something. If you have a FSM, I would start looking in there also.
Old 10-03-2009, 07:31 PM
tblt44
tblt44's Avatar
Default LCD numbers
Thanks pcolt I dont have a FSM yet
To Is there any way to make my LCD numbers darker
Quick Reply: Is there any way to make my LCD numbers darker
