Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-20-2009, 05:09 PM   #1
rebc3
CF Senior Member
rebc3's Avatar
Default need help with diagnostics
hello,
i posted before about working on a 91, 5.7 c-4. what ive done so far is change the fuel pump, fuel filter, o2 sensor, and the CTS sensor. ( owner also changed the MAP sensor and the TPS sensor) the car starts and runs great until it gets warmed up. absoulutly no codes come up any more but the car still cuts off when it gets hot! the only other clue is that right before it cuts off, it will start making a sucking noise that seems to come from the sensor under the throttle body( which also looks new). once this car starts the cutting off thing, it will start several more times but then will not start again for several hours!??
can anyone give any insight to this problem? im almost ready to give this guy his car back for no charge, because i cant fix it! is it possibly the ECM?
HELP!!!
rebc3 is offline   Reply With Quote
Old 09-20-2009, 05:34 PM   #2
vette079
CF Senior Member
vette079's Avatar
Quote:
Originally Posted by rebc3 View Post
hello,
HELP!!!
Sensor under the TB is the IAC, idle air control.
If you havenīt done it, you might want to take off the TB and then the IAC, spray it with WD-40, let sit for 10-15 minutes.
Clean the TB off course while youīre there, and put it together again.
Putting power on it (the IAC motor) will shoot small parts out of it, so put it in a plastic bag before you attempt ot test it.
I just happened to read this info elsewhere on the forum, so itīs not my personal experience. Just passing it on.
vette079 is offline   Reply With Quote
Old 09-20-2009, 08:05 PM   #3
rebc3
CF Senior Member
rebc3's Avatar
thanks! i will try that. ive never seen anything run this good and then just shut off!??
Old 09-20-2009, 08:21 PM   #4
FICINJECTORS
Supporting Vendor
FICINJECTORS's Avatar
hello,
HELP!!!
this is a common problem with multec failure. Get an ohm meter and check each injector. They should read 16 ohms. Do this with the engine hot. If you find any under 8ohms keep it unpluged and try to start. Ashorted injector will shut down the ECU on a 91
FICINJECTORS is online now   Reply With Quote
Old 09-21-2009, 05:16 PM   #5
rebc3
CF Senior Member
rebc3's Avatar
Quote:
gonna try that today, thanks!
Old 09-22-2009, 05:35 PM   #6
rebc3
CF Senior Member
rebc3's Avatar
ohmed out all the injectors. found 6 of them under 8 ohms, 1 is 2.6 ohms. only one is above 10 ohms, which the manual states is the lowest reading acceptable. guess ive found my problem. it also explains why it runs fine when its cold, because it is still in "open" loop. thanks for the tip, Im gonna replace them tommorrow
Reload this Page need help with diagnostics
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Any LT1/4 guys using a DFI ?????? Need help with tuning the stock pcm/ecm..... DieL C4 Scan & Tune 10 08-21-2003 11:19 PM
Need Help with C5 changer install with no 3-pin connection Big T C5 Tech 9 01-04-2003 05:14 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
