backup light problem?
Hey anybody, I have a 95 that when I put the car in reverse ,I get no backup lights. Checked the bulbs and the fuse, both are ok. Car has manual 6 speed. Can anyone tell what might be wrong? Thanks alot,you guys always seem to be able to help. brent317
It's the reverse switch. Located on the driver's side of the transmission, and known for being problematic. You can get a replacement at any of the normal stores. To replace it, jack up the car, and find the plug towards the front end of the transmission, up on the side. Use a 7/8" deep-offset box wrench to get it off; that's the only tool that will work, so just go buy one. I spent 2 hours trying to get it out with a garage full of tools before I submitted and went to Sears. Took 5 minutes once I got back with the wrench.
1 Post
St. Jude Donor 06-'07
No not yet. Today I ended up replacing the horn contacts . Will probably have to go buy the 7/8 box end offset first. I am still going to check the connector first to see if it is possibly corroded. Brent
Keep me posted as I have the same problem and just haven't troubleshot it any further than you have Lamps, fuses etc. Did not know this is a problematic switch. I don't back up often so its not really an issue.
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Check your license plate bulbs. They share the same wiring harness and if one (or both) of those bulbs are blown, the rear cornering lights won't come on, either.
