1990 oil cooler removal
Old 08-30-2009, 07:39 PM
looney1316
looney1316's Avatar
Default 1990 oil cooler removal
i am changing all my cooling hoses on a 1990 L98 including the small ones under the engine going to the oil cooler above the oil filter. i also got a new gasket for between the oil cooler and block (what a joke because it look just like an oil filter gasket but paid alot more at dealer for it)has any body ever replaced this gasket if so do i just twist the cooler off like a filter or what.the car has 105000 miles on it or should i just say the heck with it if its not leaking leave it alone i don't want to screw something up by going too far thank for the help
Old 08-30-2009, 08:39 PM
rodj
rodj's Avatar
Ungo the big hex nut on the cooler; that will drop it out so you can replace the seal. The nut is on a threaded sleeve that screws into the original filter mount on block
Old 08-30-2009, 08:56 PM
gmboileau
gmboileau's Avatar
If it's not leaking I would leave it alone. I think it's very unlikely that it would fail in such a way that you would lose a large quantity of oil.
Old 08-31-2009, 06:56 AM
looney1316
looney1316's Avatar
oem
Old 08-31-2009, 06:09 PM
looney1316
looney1316's Avatar
i think about $30 for both and $ 20 for the gasket i could have gotten off an oil filter
Old 02-19-2011, 01:27 PM
Dynomite
Support Corvetteforum!
Dynomite's Avatar
Exactly as rodj suggests. I had to modify my oil cooler with two additional slots so I could rotate the cooler hoses a bit more towards the block away from Headers
I rotated the oil cooler such that the two long bolts (of the spin on oil filter adapter) fit in the new slots of the oil cooler. I then tightened the big hex nut on the oil cooler
I used new NAPA 8020 and 9808 hoses cut to length replacing the old oil cooler hoses shown which work perfectly.
Old 02-19-2011, 01:42 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Dusty thread.
Old 02-25-2011, 10:02 AM
Dynomite
Dynomite's Avatar
Originally Posted by 383vett
Dusty thread.
But not a dusty solution
Old 02-25-2011, 12:00 PM
pmihaltian
Slingshot
pmihaltian's Avatar
Do you have any trouble getting your oil filter off ? Looks VERY tight.
Old 02-25-2011, 12:43 PM
Dynomite
Dynomite's Avatar
Plenty room to remove oil filter....the angle of photo just does not show it
Old 02-25-2011, 05:22 PM
mtwoolford
mtwoolford's Avatar
there's a whole series of threads on Fram oil filters, the general gist being, "I'll never buy another".
Old 02-25-2011, 05:30 PM
Dynomite
Dynomite's Avatar
I am aware of that but had that old Fram PH30 laying around so I stuck it on to keep the dirt out
I may keep that Fram PH30 on for a while after I fire it up to see how header heat effects the oil filter
To 1990 oil cooler removal
Quick Reply: 1990 oil cooler removal
