C4 Frame Diagram
Old 08-23-2009, 12:25 PM
Desert68
Desert68's Avatar
Default C4 Frame Diagram
I've done a search, but came up empty - maybe the wrong search criteria. Can anyone point me to a reasonably detailed diagram of a C4 frame? Doesn't necessarily have to have dimensions, but that would be a plus. I've been a C3 guy for a number of years, but the C4 is new to me and I have a project in mind. TIA
Old 08-23-2009, 12:34 PM
aboatguy
aboatguy's Avatar
If your planning on using a C4 frame for another project I have bad new the C4 is sort of a hybrid unibody. I know these are not what you want....but its good for a bump
and here is a pic of the C4 ZR1 chassis
Here's the bird cage
Mike
Old 08-23-2009, 01:43 PM
AGENT 86
AGENT 86's Avatar
Some info from my 86 FSM >> http://members.shaw.ca/agent86/Frame%20Specs.pdf
Old 08-23-2009, 04:53 PM
Desert68
Desert68's Avatar
Thank you for the replies. I'm interested in building something along these lines, but with one engine:
http://www.hotrod.com/featuredvehicl...ggy/index.html
I currently own a '68 coupe, been a Chevy/GM guy forever and I'm trying to figure out a way to do something like this without having to do suspension mounting points, etc, from scratch. LS3/L92, Chevy/GM throughout. The thought occured to me the other night that a C4 front/rear suspension would be a great starting point.
Thanks for the diagrams and comments.
Old 08-23-2009, 06:36 PM
jeffp1167
jeffp1167's Avatar
Buy one of those tube frames for a C3 that use all C4 suspension stuff and go from there.
Old 08-23-2009, 08:06 PM
rodj
rodj's Avatar
Get the sawzall out
Old 08-23-2009, 08:49 PM
Sweet 90
Sweet 90's Avatar
Those are cool pics Rod
Jim
Old 08-23-2009, 09:27 PM
jeffp1167
jeffp1167's Avatar
sawzall ..... the tool of choice.
Old 08-23-2009, 10:15 PM
nitronick
nitronick's Avatar
You got a link for that?
Old 08-23-2009, 11:33 PM
rodj
rodj's Avatar
http://www.sriiimotorsports.com/196382corvette.html
http://www.newmancarcreations.com/63...tte/index.html
Old 08-24-2009, 02:34 AM
nitronick
nitronick's Avatar
Old 08-24-2009, 12:10 PM
Desert68
Desert68's Avatar
Now that's one heck of an idea! Thank you.
Old 08-24-2009, 01:02 PM
MIke350
MIke350's Avatar
Has anybody ever done anything to stiffen the frame of a stripped down car like Rodj's other then the typical bolt on's? I just started a project that I plan to tear down about that far and I keep thinking how it would be worth welding in some steel to stiffen the frame but I havent looked into if its been done and how yet.
Old 08-24-2009, 01:22 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Here's another shot
Old 08-24-2009, 07:19 PM
rodj
rodj's Avatar
The only way you are going to get extra stiffness is by going the race car route with a full cage tying the front suspension through the main rollbar loop to the rear suspension.The main frame rail are a large section but there is nothing to prevent the front from twisting in different direction to the rear.Once you have a cage in there it becomes a stiffer 3D item.
To C4 Frame Diagram
Quick Reply: C4 Frame Diagram
