1995 ccm
Old 08-14-2009, 05:19 PM
pitchadude
pitchadude's Avatar
Default 1995 ccm
Where is the central control module and what does it control?
Old 08-19-2016, 12:21 PM
C5Dream2004
C5Dream2004's Avatar
Default i need the same answere today
I was told on a 95 it is behind instrument cluster but im in there and its no where ??
Old 08-19-2016, 12:55 PM
THE 383 admiral
THE 383 admiral's Avatar
as per my posted link> https://www.corvetteforum.com/forums...from-a-c4.html
Old 08-19-2016, 01:03 PM
Kevova
Kevova's Avatar
The CCM is the Central Control Module and it is essentially the body control module RKE, lighting, DIC are among it's functions. It is mounted behind center of dash not cluster I don't have a way to post pix of it's location.
Old 08-19-2016, 03:00 PM
s carter
s carter's Avatar
And it can be a bit of a pain to remove, take your time no need for Violence you don't want to brake it or the pile of wires going to it or the SIR Module not to far away from it
http://www.bing.com/images/search?q=...do0&ajaxhist=0
Old 08-19-2016, 07:06 PM
WVZR-1
WVZR-1's Avatar
Received 2,271 Likes on 2,032 Posts
There's 2 images in this link. They're of a '92 but all years are very similar and require essentially the same components to be removed before you've got it in hand.
"C5Dream" - what issues do you have? There's lts of diagnostics that need to be/could be done befre you go into the dash etc.
https://www.corvetteforum.com/forums...p-or-down.html
To 1995 ccm
Quick Reply: 1995 ccm
