Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-13-2009, 09:24 AM   #1
jmgtp
CF Senior Member
Default Bad OptiSpark?
Hello! Yes, I am a new guy.
Just picked up my 94 C4 yesterday and am quickly falling in love with it!
It made a 50 mile trek home without issue but I noticed on my second drive that the engine was skipping occasionally and the tachometer would jump erratically at the same time. I assumed this must be the famed optispark that I've read about. I'm more familiar with the GM DIS setup and the best I can relate this issue is that it feels like a failing ignition module or a bad crank sensor/wiring... that said, I'm not sure if the LT1 uses an ignition module or if it is built in to the optispark. I'm sure it must have a crank sensor for the fuel injection but does it use it in relation to spark timing as well?
I want to replace the optispark, coil, wires and plugs in the near future. I've read that the vented MSD optispark replacement is the preferred choice. I've seen them labeled optispark and optispark II? Is there a particular one that I need? What about coil and wires, MSD a safe choice here as well? Plugs? I'm a fan of AC Delcos but open to whatever works best.
I'm not new to wrenching around a car/engine and dare I say I'm pretty good with a wrench. I have plenty invested in tools, compressors, etc. to get just about any job done. I'm new to the LT1 though and if there is a how-to written up on how to replace the optispark I would sure like to see it.
I guess this post can't be complete without at least 1 pick of my new car... here is what I think is one of best looking parts of this car, its butt:
Click the image to open in full size.
jmgtp is offline   Reply With Quote
Old 08-13-2009, 10:42 AM   #2
onedef92
CF Senior Member
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
onedef92's Avatar
Check your plugs and wires, first. These HEI ignition engines are very sensitive to bad coil and plug wires. A bad wire or wires can easily cause symptoms you're describing.
Open the hood at night or in a darkened garage, start the engine, then pull the hood lamp fuse. Look for any telltale electrical arcing and/or "creepycrawlies" along the wires.
What shape are your plugs in? I'd consider swapping them out, too. NGK TR-55 Double Platinum is an excellent plug.
onedef92 is offline   Reply With Quote
Old 08-13-2009, 04:11 PM   #3
jmgtp
CF Senior Member
Thanks for the response. I don't know the age/condition of the plugs - just got the car yesterday. I can see how a ba coil/plugs/wires would cause the skipping but could it also cause an erratic tach. That said I do plan on replacing plugs/wires and coil. I guess I'll do those first and see how it runs before replacing the optispark.
Old 08-15-2009, 08:07 PM   #4
tblt44
CF Senior Member
tblt44's Avatar
I just got a 95 last week and it looks like a job just to put new wires on.I have oil around and on my optispark so I think I have to replace my intake gasket
Mine has 71,000 and I don't know if the plugs have ever been replaced.Wire look original.
Mine seems to have a small mis.
tblt44 is offline   Reply With Quote
Old 08-15-2009, 09:02 PM   #5
jaa1992
CF Senior Member
Cruise-In III Veteran
St. Jude Donor '12
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
James Anderson
Send a message via MSN to jaa1992
OK, looks like we have two different posters with different issues.
jmgtp - With no codes its more likely to be wires, ICM, or coil. The ICM and coil are mounted on the passenger head.
tblt44 - oil behind the opti means the seal is probably bad in the timing cover, not intake unless you can trace it all the way back.
When I had to replace my opti I had a small leak at the waterpump seal. Just replaced it when I did the opti and waterpump.
For vented stock opti an AC/Delco replacement is fine. If want to spend more money MSD or Dynaspark are an upgrade. Non-vented opti go with the MSD or Dynaspark. I put a Dynaspark in because the only choices at the time were Dynaspark and Accell. No way would I put an Accell on, I didn't want to have to do it again.
jaa1992 is offline   Reply With Quote
Old 08-16-2009, 09:16 PM   #6
vetteblack
CF Senior Member
vetteblack's Avatar
That sure is a great looking car! hope you get things ironed out with it soon.
vetteblack is offline   Reply With Quote
Old 08-17-2009, 09:15 AM   #7
onedef92
CF Senior Member
onedef92's Avatar
Here's a coil and ICM pic for you guys as a visual reference.
Old 08-17-2009, 12:46 PM   #8
jmgtp
CF Senior Member
Thank you all for the responses and the pic.
My coil does look to be in beat up rusty condition. I am surely replacing it and plugs/wires.
Sometimes it runs great, other times it barely runs. What bothers me is that the tachometer behaves erratically. I imagine the output signal for the tach comes from the optispark. For that reason alone, it makes me want to think that my optispark is the problem. I don't mean to step on the toes of what you guys have suggested but this is just what is running through my head, is my logic sound?
The below link is a video of the car at idle. I am not touching the gas pedal at all. You can see the tachometer do some weird spikes. While the 'spikes' report an increase in engine speed the engine is actually misfiring and losing rpm then the idle air controller tries to compensate and it revs up a little. Could a bad coil/wires/plugs cause the tach to do this? The optispark is new to me, I'm familiar with GM DIS systems like the back of my hand but the optispark is a whole other game.
Link: http://www.youtube.com/watch?v=JLoqKq33Ws0
thanks for looking!
Old 08-17-2009, 02:10 PM   #9
onedef92
CF Senior Member
onedef92's Avatar
Embedded to help a Brother out....
I'm wondering if you might have a bad voltage regulator in your alternator? Do you get spikes on the voltage meter on your dash readout, too.
Old 08-17-2009, 05:26 PM   #10
desertmike1
CF Senior Member
desertmike1's Avatar
I'd be doing a whole lotta "Grounding" checks, and cleaning right outa the gate, and as previously recommended, check your Alternator output with a hand held DVOM.
Oh ya...Buy a FSM, they do help.
desertmike1 is offline   Reply With Quote
Old 08-17-2009, 06:04 PM   #11
jmgtp
CF Senior Member
Thanks for the replies and keep them coming!
I haven't noticed any voltage spikes that accompany the tach jumping/engine stutter. The gauge remains steady and the digital output near in the speedometer screen seems steady at ~14.2v. I'll throw the meter on the car next time I'm at the garage to verify but as it sits I don't suspect the alternator.
I'm going to change the coil with an MSD unit and replace the wires/plugs as well. That will be my first step, if the problem persists after that then I'll let you guys know!
Thanks again, John
Old 08-17-2009, 06:17 PM   #12
95BLKVette
CF Senior Member
95BLKVette's Avatar
I had this happen on my daughter's Dodge Avenger recently...I finally traced it to the main ground to the engine being loose. It caused all kinds of misleading codes to be thrown, and the idle was doing excatly what yours is doing.
BTW, check for codes. You can see how to do this with a simple paperclip on your 95. The DIC will then show you if any codes have been thrown.
Check your grounds
Also, if you plan on doing your own work on the car get the 2 volume service manual....If I remember its about $160 from Helms
__________________
10/99 95 Blk LT-1 Cpe 383 LT1, J&E Forged Pistons, Eagle Forged SIR Rods GM Hot Cam,1.6 RR, Ported Heads, 30# Injectors, PaceSetter Shorty Hdrs, 3" SS Exh, LT1-Edit, Accel 300+, 160 Thermo, Tbody Bypass, LT-4 Knock, 9" ProTorque 3,000, 129K mls (5/07) Self-rebuilt 4L60E
12/30/04 99 Torch Red Vert, Tan Int, Blk Top, Auto, 21K mls (5/07 58K mls). Twlt Sent, HUD, Pwr Lthr Sport Sts, Memry, CV Real Time Dmpg, Pwr Tele Str Whl, 12 CD Chngr, Dual Clmt Cntrl, Active Hdlg, Trctn Cntrl, Fog Lmps.
95BLKVette is offline   Reply With Quote
Old 08-17-2009, 08:02 PM   #13
Bob2.0
CF Senior Member
Bob2.0's Avatar
Send a message via AIM to Bob2.0 Send a message via Yahoo to Bob2.0
Default Me too!
I've got a 94 that I'm i love with too. Great car. It was missing a bit at first, and got progressively worse. A friend recommended putting Techron in on top of a full tank of Chevron, as the injectors could use the cleaning, which helped ALOT.
I'm sure my opti will need changing too as I've noticed a very small drip of antifreeze under the car where the waterpump is but it is runnng better now with the fuel treatment. I will be watching this thread though to see how you manage it.
Congrats on the 94!
Bob2.0 is offline   Reply With Quote
Old 08-17-2009, 09:16 PM   #14
jmgtp
CF Senior Member
I assumed the paper clip trick wouldn't work to read codes on the 94 ecm. I have a 91 Grand Prix that I use this method. I was under the impression that the OBD 1.5 introduced in 1994 eliminated that option as well as making tuning much more of a pain. I have an OBD I cable that I use on the Grand Prix to interface to my laptop through TunerPro RT. I also have all the hardware and capability to burn new eeproms which I do for the Grand Prix - if that is possible with the 94 Vette ECM that would be great.
The check engine light isn't on, but I suppose there could be codes stored.
I'll have to do some searching for a service manual, $160 is a bit steep right now given that I just purchased the car, paid registration, and I bought a coil/plugs/wires this evening for just under $200.
If it matters... I went with an MSD Street Fire Coil, AC Delco Rapid Fire #14 plugs and AC Delco Wires.
Old 08-17-2009, 09:40 PM   #15
jstout30
Junior Member
jstout30's Avatar
Paperclip still works on a 94.
See the bottom of this link:
http://www.corvettebuyers.com/c4vettes/codes.htm
I'm an interested observer on this one, as I'm having a similar unresolved issued with my 93 even after replacing the ICM.
-John
jstout30 is offline   Reply With Quote
Old 08-18-2009, 08:37 AM   #16
ChrisWhewell
CF Senior Member
ChrisWhewell's Avatar
Congrats on the 94!
chevron gas already has techron in it
ChrisWhewell is offline   Reply With Quote
Old 08-18-2009, 08:00 PM   #17
John Row
CF Senior Member
John Row's Avatar
If the tach is jumping around it's probably a 97% chance the opti is going out. You might even get some codes (using the paper clip method).
Since it's a new car for you, a new set of wires and plugs would be money and time well spent.
Optis have come way down in price, last time I did it, I was happy with $250. Now ebay has them for $90 shipped!
Doing the venting thing is a good project as well. While you're in their take a good look at the vacuum lines. 15 years is a really long life for rubber hoses and fittings.
I'll be replacing my opti pretty soon (again!). It's a full day job the first time, about 3-4 hours the second time. The hardest part is figuring out "how the -f- do you get a wrench on that m-f bolt!!" Take heart, you can get to all of them.
Cheers - JR
John Row is offline   Reply With Quote
Old 08-23-2009, 11:04 AM   #18
jmgtp
CF Senior Member
I too thought that the tach jumping had to mean a bad opti. However, I installed new AC Delco Rapid Fire 14 plugs, AC Delco wires and an MSD Street Fire coil and it runs like a champ. No more skipping and the tach behaves normal all the time. I also discovered that my throttle was not opening 100% - the adjuster near the ASR took care of that and now the LT1 is running like it should. I am very happy with it right now!
Thanks to everyone who responded, my problem is solved!
I did the intake mod while I was in there and removed the fins off the airbox lid. I don't know if there were any real world gains from it and I don't think I notice any difference in sound. It does have an aging paper filter that should probably be replaced. At $80 I'm wondering if the K&N is really worth it or if I should just go with an aftermarket intake system for a bit more? If the aftermarket intakes are only worth a few ponies then it would be hard to justify the cost and I'd rather put that money towards exhaust or gears.
Old 08-23-2009, 02:09 PM   #19
jaa1992
CF Senior Member
St. Jude Donor '12
jaa1992's Avatar
James Anderson
Just put a new paper filter in there.
Reload this Page Bad OptiSpark?
Tags
92, bad, c4, corvette, dis, erratic, find, lt1, opti, optispark, spark, symptoms, tachometer, testing, tools, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Optispark again! Kinkajou C4 Tech/Performance 33 08-30-2005 08:54 PM
optispark and no start code 16 then 42 pci_raid C4 Tech/Performance 20 01-12-2004 02:05 PM
Help I did some modes to my c5 a4 and now it is missing bad and ce light flashes ownedya C5 Tech 10 12-12-2003 07:30 PM
My working optispark theory Nathan Plemons C4 Tech/Performance 38 05-07-2003 10:16 PM
Bad Optispark? Valleybacker C4 Tech/Performance 26 04-24-2003 04:30 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
