Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-12-2009, 04:07 AM   #1
arrested609
Junior Member
Default MAF Power and Burn Off Relays PLEASE HELP !!!!!!!!
I'm wanting to change both my MAF power and burn off relays on my 1988 Corvette. Are they the Same number relays ?. IF not which one is the BURN OFF relay if your looking from the front of your vette looking at the fire-wall. Is it the left one or the right one. Thanks, Craig.
arrested609 is offline   Reply With Quote
Old 08-12-2009, 08:13 AM   #2
CorvetteMike2004
CF Senior Member
Support Corvetteforum!
CorvetteMike2004's Avatar
Default Relays
They are the same. Change both of them. They are inexpensive anyway. Your replacement relays will probably come from India. Also clean your maf with some spray MAF cleaner.
Corvette Mike
CorvetteMike2004 is offline   Reply With Quote
Old 08-12-2009, 01:29 PM   #3
arrested609
Junior Member
Default Hey
Thanks Mike that will help me.
Corvette Mike[/QUOTE]
Old 08-12-2009, 04:01 PM   #4
jeffp1167
CF Senior Member
jeffp1167's Avatar
there was a guy on 3rd gen who found a difference with them. I can't recall what it was, they look the same externally but something was different inside of them. He thought this to be the cause of most maf related codes being thrown in cars.
jeffp1167 is offline   Reply With Quote
Old 08-12-2009, 04:11 PM   #5
CorvetteMike2004
CF Senior Member
Default vette
Quote:
On my 89, they are the same.
Old 08-12-2009, 04:21 PM   #6
jeffp1167
CF Senior Member
jeffp1167's Avatar
Quote:
I think this was a pre-89 thing, something about resistors in it that werent in the power relay.
Old 08-12-2009, 04:24 PM   #7
rick lambert
CF Senior Member
rick lambert's Avatar
Mines an 87 and I'm 99 percent sure there the same.
rick lambert is offline   Reply With Quote
Old 08-12-2009, 04:35 PM   #8
jeffp1167
CF Senior Member
jeffp1167's Avatar
Quote:
ahhhh the 1% can always mess you up everytime
Old 12-13-2009, 06:50 PM   #9
JordanSmith
Junior Member
Default a mess of MAF
I am getting error 34, on and off, upon starting the 87 vet. I know there are MAF relays, but can't find the location of. The 2 shop manuals I have just say "check em".
There are 4 sliver units in the fuse box for which I also cannot find or determine function of.
Some say the green wire from MAF to ECM is bad, some say the exhaust is plugged up and messing with the air flow.
I would hate to change relays, MAF, and ECM, only to get the "Check engine" light again.
Any ideas would be great,
Tanks,
Jordan
JordanSmith is offline   Reply With Quote
Old 12-13-2009, 06:56 PM   #10
CorvetteMike2004
CF Senior Member
Default vette
Tanks,
Jordan
Check the electrical connection going into the MAF itself. Sometimes those metal tips get corrosion on them.
I have had this happen to me. Good Luck
Corvette Mike
Old 12-13-2009, 09:04 PM   #11
JackDidley
CF Senior Member
JackDidley's Avatar
I have an 87. They originally had 2 different part #s but now just one is used. I have no problem with the replacements. I' think the MAFs are the same over the years.
JackDidley is offline   Reply With Quote
Old 12-14-2009, 10:45 AM   #12
Baldfart
CF Senior Member
Baldfart's Avatar
I have a 87, and when I purchased it, it had a code 34. The previous owner had put in a new MAF. He said they couldn't figure out what was going on. He had even checked for shorts in the wiring harness. All I did was replace the two relays and it solved the problem.
Baldfart is offline   Reply With Quote
Old 12-14-2009, 05:49 PM   #13
JordanSmith
Junior Member
Corvette Mike
Tanks C.M.
I have check the 4 poled plug into the MAF, the connectors on the EMC look "old" and grey, not copper color.
I get the code 34 on and off, when I start the car, and if I turn it OFF and try again, I won't get the code.
Very fustrating, as I have been able to change the clutch, brakes, deal with the parasidic drain from the LCD, and the faulty radiator, but this intermitant error code really chapps my hide...
Are the relays around or next to the Spark plug advance connector that I had to un-hook to do the timing ???
Old 12-14-2009, 08:46 PM   #14
C409
CF Senior Member
C409's Avatar
On my '87 they are on the firewall just above the battery ... one is parallel to the FW and the other is perpendicular ... but they are attached to the same bracket ...
C409 is offline   Reply With Quote
Old 12-14-2009, 09:18 PM   #15
88flyer
CF Member
Default MAF relays
change them both, they are the same part one is power to the MAF the other is power to the burn off circuit, by the way the burn off is the outboard one of the two (side by side behind battery) if you do get a code disconect batt. for 20 seconds and back on again that should take care of it.
88flyer is offline   Reply With Quote
Old 12-16-2009, 07:53 PM   #16
JordanSmith
Junior Member
Default Free pen inside...
Thank you C.M. and 88,
I see em, never would have looked there. Right below is a power "Block" with 12volt feeds: I see a red wire on top of them all, that someone used to "Steal" constant radio power to the aftermarket CD player my Dad had put in "Professionally" (ha ha ha...) Right now I am un hooking the feed to the CD player if that had anything to do with it, maybe no, but I would rather the radio be on the radio fuse. And now I can replace the MAF relays thanks to you guys.
Hey ! working on your own VET can be profitable...
I found a 1989 "Valley Corvette" ball point pen inside my radiator! for FREE !!
...I should go buy a lottery ticket...
Old 01-04-2010, 11:26 AM   #17
JordanSmith
Junior Member
Default MAF relay seems to solve the "34"
New maf relay from CHINA seems to have solved the error code 34. Thanks so much for the help and input to all you guys.
..Of course, it never ends, as soon as I installed the relay, the Alpine CD player decided to keep the CD and not play it or eject it... Radio still works though....
Hope everyone had a Good and safe new year...
Jordan
Old 10-28-2011, 06:17 PM   #18
87Vetteowner
CF Senior Member
87Vetteowner's Avatar
THis may be a little late to the thread but from our newsletter:
Tech Tip#1: For C4 Corvettes in the 1987 to 1989 vintage, you may
experience a Trouble Code 34. This code was used on many OBD-1 Computer
Control Systems to indicate a problem with the Manifold Absolute Pressure
Sensor or the Mass Airflow Sensor. Early C4's had the Manifold Absolute
Pressure Sensors, later ones do not, so when the code 34 appears, most shops
change the Mass Airflow Sensor hoping the problem will be fixed, but then
the Check Engine light comes on again. GM Technical Support provides
additional service advice to correct the intermittent Check Engine light
(Code 34). End result is 2 relays can cause "Code 34" in 1987 and later
Corvettes:
1. Mass Air Flow Relay (pn 14089936 , it also maybe another number)
2. Burn Off Relay
If you are having this problem, save yourself lots of expense and trouble
and replace those two relays.
__________________
Have a great day !
87Vetteowner is offline   Reply With Quote
Old 10-28-2011, 06:44 PM   #19
JordanSmith
Junior Member
Default It was the relays
[QUOTE=CorvetteMike2004;1572419359]Check the electrical connection going into the MAF itself. Sometimes those metal tips get corrosion on them.
Corvette Mike [/Thanks mike turned out to be the relays]
Old 10-28-2011, 07:01 PM   #20
WW7
CF Senior Member
WW7's Avatar
[QUOTE=JordanSmith;1579080001]
Just for future reference you are always suppose to change both relays whenever you change a MAF sensor......WW
WW7 is offline   Reply With Quote
Reload this Page MAF Power and Burn Off Relays PLEASE HELP !!!!!!!!
Tags
1984, 1988, 87, 89, burn, burnoff, c4, corvette, location, locations, maf, power, recall, relay, relays
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
CAT & Surging ??? ECS Guys please read C5kid C5 Forced Induction/Nitrous 22 11-19-2004 11:52 PM
Need help REALLY fast PLEASE VetteNoob C4 Tech/Performance 21 10-10-2002 11:48 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
