Extrude Hone
Old 02-23-2010, 03:30 PM
Marv02
Marv02's Avatar
Default Extrude Hone
Ok I still trying to figure out a way to get around Calif somg laws ya so much fun
The main problem is with my 1986 vett is the intake manifold I was thinking getting it Extrude Hone so it flow more CFM's and still have the stock look so it will still pass smog.
I need your input do you think this will work to get more flow so i can use better heads and still pass smog.
Old 02-23-2010, 03:59 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
I had my intake and SuperRam runners Extrude Honed years ago. Very happy with the result.
Old 02-23-2010, 04:02 PM
65Z01
65Z01's Avatar
Cruise-In II Veteran
Though extrude hone of the base would help, you would need LT runners, like the AS&Ms, to really help flow.
As an altenative to the "stock look", I've done the siamese intake base:
-cut a hole 2" deep x 1" high into the adjacent base runners
-cut about 1/4" deep x 1" high into the lower runner base to blend with the base openings
-smooth and stream-line the openings in base & runners
-open up the lower funner gaskets to match the new openings
This mod will increase breathing at top RPM while not taking away an appreciable amount on the low end:
Before: 185chp @5,600rpm
After: 215chp @5,600rpm
BTW, with this mod, 1.6:1 RRs, 160deg T-stat, open air cleaner lid, hi-flow cat, cut-back spark plugs she easily passed the OH E-Check dyno sniffer.
Old 02-23-2010, 04:43 PM
Marv02
Marv02's Avatar
Is this combo smog legal in Caif thats what I am looking for.
Old 02-23-2010, 04:48 PM
cumbercr
cumbercr's Avatar
The Super Ram combo is legal in CA. I have a copy of the EO. The SR intake manifold is legal by itself and is readily available.
Old 02-23-2010, 05:01 PM
Marv02
Marv02's Avatar
Thanks a lot thats what I been looking for.
Old 02-23-2010, 05:25 PM
383vett
383vett's Avatar
Get ready to join the SuperRam club.
Old 02-23-2010, 05:35 PM
cumbercr
cumbercr's Avatar
I see another thread coming on tips and tricks for installing the SR.
Old 02-23-2010, 05:46 PM
383vett
383vett's Avatar
Here we go again...
Old 02-23-2010, 05:50 PM
Marv02
Marv02's Avatar
I think I going to go with getting the OEM stuff honed out
It seems like the SR is more for high rever I not looking for that.
I looking for a motor that turn 5000 to 5200 RPM's.
Its looking like Hone the intake and runners a a set of Trick flow heards will get the motor what I want it to do for now
Old 02-23-2010, 07:43 PM
ex-x-fire
ex-x-fire's Avatar
Call edelbrock, they make smog legal tpi intakes, & they have head/cam/intake combos.
Old 02-23-2010, 07:56 PM
Aardwolf
Aardwolf's Avatar
The runners are thin like paper. The SR doesn't have to be a high RPM intake.
Old 02-23-2010, 08:27 PM
383vett
383vett's Avatar
The SuperRam is known for it's broad, flat torque curve; it's not meant to be a high rpm intake setup.
Old 02-23-2010, 08:52 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
You can port the base plenty, sniffer cant pick that up. We actually have lenient sniffer standards out here. If your car is in good tune and you pass the visual you have no problem.
If it was me just porting the heads, intake aftermarket runners and a small cam/tune would make for a fun street legal car.
Did a 305 to 350 conversion on a freinds IROC last year. Edelbrock heads that got some porting, a Lunati 236Voodoo cam, ported TPI system nd shorty headers, car runs syper strong. Even with a rich mail order tune it easily passes Ca smog.
Old 02-23-2010, 09:03 PM
ch@0s
ch@0s's Avatar
Unless you are looking for big power this is not a bad plan.
Old 02-23-2010, 09:39 PM
cv67
cv67's Avatar
St. Jude Donor '05
True..wont be a screamer but should give plenty of noticable fun on the street without spending a bunch if you can do your own work.
Old 02-23-2010, 10:05 PM
Caboboy
Caboboy's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22
'23-'24
Marvin, extrude honing is gonna cost you $800 plus shipping both ways. You can do a decent SR for that money & have a unit that will out perform the stock extrude honed intake hands down. Then you can sell the TPI stuff & get a few bucks back.......I think you'd be way ahead of the game going that route.
Another thing.........cubic inches don't affect smog compliance, so perhaps think 383 because that would be like a 350 on steroids (all other parts being equal). Add a decent set of heads (nothing too expensive), a 219 cam, and you'd have a car in California that would be perfectly legal and kick some butt. I applaud you for working towards the best of both worlds; performance and legality
I bet you'll want more within a year, so put some forged pistons in while you're at it
To Extrude Hone
Old 02-23-2010, 10:07 PM
cv67
cv67's Avatar
St. Jude Donor '05
Caboboy has a smog legal monster for sure, lots of cubes
Old 01-10-2012, 05:37 PM
Jim McCombe
Jim McCombe's Avatar
Willie,
I am in the process of doing that right now...
Is there a annual club membership fee to become a member of this elite group?
Old 01-10-2012, 05:42 PM
Jim McCombe
Well put Tim and good advice.
Quick Reply: Extrude Hone
