Oil temp help please
I have an 86 w/92K, runs fine.
My question is, when driving on the interstate ~80mph the oil temp shoots up to 240 and stays there but the coolant temp is at 205. Should this be?
If not normal any suggestions??
BTW I live in FL, it is 92 today
ideally oil temp should be about 15F-20F above coolant temps ID suggest an oil cooler and larger capacity baffled oil pan
http://forum.grumpysperformance.com/...php?f=54&t=296
adding a DUAL oil cooler & transmission fluid cooler seems like a good idea
http://www.summitracing.com/parts/PR...5&autoview=sku
My 1986 does the same thing, oil temp is always 20 to 30 degrees higher then the water temperature.
