(LT1 Question) Installing a new rear coolant vent tube
I'm cleaning up my engine bay and one item on my list is installing a newer style vent tube like this:
I'm dumping my heater core and the current vent line runs there. What years had this style?
Is it a difficult job to install a new one without pulling the motor?
Thanks,
Jeff
Thanks,
Jeff
GM part number 10108636 has been discontinued. I checked several of the aftermarket places and you might be able to find one. My new engine came from Golen Engines
http://www.golenengineservice.com/index.html
According to them they never bother to replace the vent tube assembly so I didn't bother. I haven't run the car much since I put the engine in (brand new opti crapped out after 5 auto-x passes) but car ran very cool in FL heat.
The steam tube vents air and steam from the rear of the heads. There is also coolant flow between the heads. Remove the tube and you will possibly overheat cylinders #7 and 8.
Here;s my tale of woe: When my son;t 96 LT1 was removed for a heads and cam changed, I re-installed the vent tube but DIDN'T change the washers. BIG MISTAKE.
After re-installing the engine and firing it, the passenger side washer developed a coolant leak. I tracked down two replacement washers and unscrewing the passenger side bolt wasn't a problem : BUT STARTING IT AGAIN WAS A PURE NIGHTMARE!
I took a day and a half, maybe 10 hours over-all to just get the bolt to start. It tooke me and an engine savy neighbor to finally get it started.
Now remember, that was only ONE BOLT, NOT BOTH OF THEM. Saying it was a PIA is putting it very mildly.
How hard the driver's side would be, I can't say. I'm just happy I didn't have to deal with that one too.
Also, my recommendation: DO NOT delete that vent tube. You'd be asking for trouble down the road.
Jake
West Point ROCKS! Nation's Top College per Forbes Magazine!
Jake
Lt 1 vent tube bolts
Jake
Jake
anybody I am trying to replace the head gaskets and the vent tube must come off what size wrench do you need it not 5/8 and not a 15 metric ????
Thank s for your Help but does but does any one know what size wrench to use to remove the stock vent tube bolts 15metric seem to big a 14 too small a 5/8 too big a 9/16 too small ?? I didnt want to destory it thank again it 94 LT1
I do remember the bolt heads being a little funky. The last time I Pulled the heads with it connected and then was able to get the wrench on correctly. IIRC it was a 14 but it only fit one way.
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Ive done it twice with the engine in the Vette. A 15mm and torque to 30 lb-ft
If that tubing is no longer available try a junk yard or use your imagination. Cooling system hoses, two threaded 90* elbows and a "T" connector will get the job done.
I got em off it was 15 metric a wrench wouldn't work so I used 15 metric socket and a prayer and it worked I was very worryed so I thanked the Lord for his help , and Question 2 on a lt1 Corvette the vent tube goes from the heads to the radiator are to the coolant tank I am doing a 94 LT1 and 4L60e swap into a 86 Camaro IROC Z I got a blown head gasket and the shop I took the heads too told me it had to do with the vent tube and where was it connect too thanks for your help
I need pictures are diagrams on how vent tube connects to rest of cooling system are where it go form the heads on the left side to ??? and thank you for your help I have some diagram for the 93 94 it looks like it connects below the over flow on the radaitor and the other diagram it looks like it going to the throttle body but not sure
On my 92 there is a rubber hose that goes to a connection on the expansion tank.
