replacing transmission. Use new ZF?
I am replaceing my trans in my 92 lt1. Should i go with a new zf sixspeed? or are there better options? any help is greatly appreciated.
thanks!
thanks!
I have heard that the ZF can be a problematic transmission. Is this a good idea to replace with a brand new zf or should i consider other routes even though it will not be a direct bolt in.
the ZF can be noisy w/an aluminum FW, but good luck finding a more durable manual gear box....they can take a beating....never heard of many people having problems w/them....the hydraulics can start leaking from the master/slave cylinder but that is not an issue with the transmission itself.....
