Power Door Locks don't work
Old 07-26-2009, 10:17 PM
PPP Big Dog
PPP Big Dog's Avatar
Default Power Door Locks don't work
On my 1987 vette, the power door lock switches do not work.. I Checked the fuses and relays in the fuse box. Any idea what else it could be?
Old 07-27-2009, 03:55 PM
PPP Big Dog
Any help?
Old 07-27-2009, 04:13 PM
ddahlgren
ddahlgren's Avatar
On my 91 I have secondary fuse blocks under the passenger side of the dash and had a blown fuse there when mine did not work not sure if helpful to you. You might also poke arond and see if anyone installed an aftermarket alarm system that caused dozens of things to not work until we had the 'alarm exorcisim' LOL..
Old 07-27-2009, 09:10 PM
PPP Big Dog
wow, i just found 2 small I mean very small toggle switchs under the driver side down by the brakes. I flipped one and I do not see that it does anything. it is a 2 way switch. the other switch is a 3 way toggle and in one position the car will not start.
i think i will keep that one a secret so as my 14 year old comes of driving age and we are away for the weekend, i can be SURE that he can not crank the vette.
Old 07-28-2009, 12:35 AM
AGENT 86
AGENT 86's Avatar
http://members.shaw.ca/agent86/Power%20Door%20Locks.pdf
Old 07-28-2009, 02:21 PM
PPP Big Dog
Thanks 86
Old 08-30-2009, 02:16 AM
scheidecker
Cruising
scheidecker's Avatar
Hi 86,
I could not find the power locks doc. I am having issues with my 92 power lock switches on the door. Thanks for the help.
Old 08-30-2009, 08:11 AM
AGENT 86
AGENT 86's Avatar
Originally Posted by scheidecker
Hi 86,
Reloaded the page, keep in mind it's from the 86 FSM.
Old 11-20-2009, 02:14 PM
samsonb
samsonb's Avatar
On my 89, I had the door panels off for a year. I went to put the door panels back on and noticed both power door locks didn't work. The switches were good because they moved the windows.
I played with it for 2 hours and couldn't get them to do anything. I read Agent 86's pdf file and got a test light on the Orange/black wire to the negative battery post, and the test light lite up. So, I put the switch back in, and now both switches are locking/unlocking the door.
I have no idea what changed from 2 hours ago, but now they both appear to be working.
Old 11-20-2009, 03:01 PM
engle1147
Support Corvetteforum!
engle1147's Avatar
I've had problems with those over the years. The connector sockets on the swithes were most likely the problem since they are not really sealed from the elements so corrosion creeps in at the connections. Reseating the harness connectors should get them going again for awhile.
Old 11-20-2009, 09:57 PM
samsonb
samsonb's Avatar
I'm not too sure as both didn't work. I cleaned the contacts on the switches. And I had spent 2 hours plugging and unplugging the door lock switches, and swapping them back and forth. And both still didn't work. I even tried using the power window switches, and they didn't do anything.
I went inside and did some searches and came across this thread. So, I grabbed my test light, and it lite up on the Orange/black wire. So, I connected both switches back up and they both started working at the same time.
So, I think it was something else going on since both didn't work at the same time, then all of a sudden both started working again.
Would that theft deterant have anything to do with it? I think I read that if the theft deterant goes bad, it shouldn't affect the door lock switches?
All I've got left to do is get another mirror toggle switch. As my old one was failing on the "up" position. I drilled a hole to clean the inside and I must of drilled in the wrong place as the toggle switch didn't do anything the next time I plugged it up. Bought another one from someone hear, and it doesn't do anything. So, I'm guessing I either got a bad switch, or something is going on like with the power door locks.
Old 11-21-2009, 11:24 AM
engle1147
engle1147's Avatar
Those are momentary DPDT switches in there if you have problems with one of the switches both can/will act up. Do not attempt to clean the contacts inside the switches themselves....waste of time and you'll damage the plastic housing...get a new ones instead - clean the harness connections before installing them. Most likely only the drivers' side is culprit since it gets the most use/abuse.
Old 11-21-2009, 01:12 PM
samsonb
samsonb's Avatar
Oh, didn't know one side affected the other. The part I cleaned was the brass prongs that you plug into the white connector. I got to thinking about it. I might of only had one plugged up at a time, so that probably was it then. Haha.
I need to get another one anyways, or at least the bezel as when I had the driver plugged up. I shut the door and it broke the mounting pieces of the bezel on the switch when the door hit it to the door sill. I have the door panels off so the wires were dangling.
By the way, what could cause the mirror toggle switch not to work? Is it simply either the toggle switch is bad or the selector switch? Or the mirrors aren't plugged up? Is that the only things to look at, as the toggle switch I just bought doesn't do anything. I'm gonna try to bypass the selector switch with two paper clips to see if that does anything.
Old 11-21-2009, 03:10 PM
odecom5
odecom5's Avatar
I have a similar problem. My power lock BUTTONS work, and they even make the locking noise, but the locking mechanism doesn't work. I am taking apart the door panel this weekend, will let you know what I find!
Old 11-21-2009, 03:36 PM
engle1147
engle1147's Avatar
The actuator rod probably came off the door lock's armature or the door lock solenoid....I've had both happen... if you can push the door lock shut manually and the door locks the the problem is not at the "lock" so look to the solenoid for issues. Below is a link for a quick fix for busted plastic clips on the door lock solenoid rod.
http://forums.corvetteforum.com/c4-g...actuators.html
Old 11-30-2009, 05:36 PM
samsonb
samsonb's Avatar
I believe they sell those clips at Autozone in the Help section. If not, I'm sure you can still get them from the dealer.
To Power Door Locks don't work
Quick Reply: Power Door Locks don't work
