Installing the 421.....
#124
Certainly is alot of bucks involved. I was lucky to have Jim in my corner in regards to cutting a few costs, or I might of not of been able to build the 421. If it wasn't a 421, it would be been a 383.
I am hoping we can turn it over July 1st, and I can hear the idle of the 236/242 with all those cubes.
#125
St. Jude Donor '10-'11-'12-'13
#126
I hear what your saying about those LS-7's as they are just nasty when modded, but not many modded one's in my parts. I have a feeling when I get this bitch running, and fully tuned a stock "
LS7 won't pull as strong. I drove a stock 07 not 2 long ago. Don't get me wrong it was fun, but I am expecting more with the 421.
#127
I noticed you are in the green. Looking at prices for used C5 Z06's?
#128
Well I got the fuel issue sorted out I believe. I found some time to mount the MSD coil blaster a few days ago, and I might be getting a custom SS bracket made up from LD85's friend for the MSD. Thought I would shoot a few pics up.
Yes the car is still sitting on the hoist, but it will be started up in good time. As you guys can tell I am in no hurry, but it will see some road before it snows.
#131
Awesome garage and lift, BTW! Now start cleaning that engine bay!!
#133
Had a little set back. Just some personal stuff, but I am back at it somewhat......
Made a little progress. Had a bracket fabricated for the MSD. It didnt fit perfect, but I'll I had to do has shave a little off the one corner, and bingo!
My plan is 2 get the car started this month as my wife is due in 7 weeks with our second.
Also looks like I found a dynojet.
Cheers!
Cheers!
#134
Received 3,043 Likes
St. Jude Donor '05
No more posting threads for Ricky until it actually runs.
#138
I used the normal procedure I'd used for decades, including filling the new Fram filter with fresh oil. On starting the engine ZERO OIL PRESSURE!
I immediately shut down the engine and double checked my work - no leak or sign of anything being wrong.
Re-fired the engine - ZERO OIL PRESSURE!!
I replaced the Fram filter with the old ACDELCO, the one I had just removed, re-re-fired the engine and pressure returned to normal.
I'll never use a Fram oil filter again!!!
Jake
#139
