Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-21-2009, 01:10 AM   #1
Calderone
CF Senior Member
1987 Chevrolet Corvette
Calderone's Avatar
Default How much HP / TQ would this combo make ?
Again with the old How much HP/TQ question but i think im deciding what to do,last year i told you guys that this midyear i was planning to purchase some aftermarket heads,im collecting the money to get some AFR 180's.- After that..this is my goal for the intake (if i not choose FIRST intake)
- Siamesed Plenum
- Siamesed SLP Runners
- Edelbrock Baseplate (what's the difference between #3860 and #3861 ??)
- Edelbrock 52mm TB (not sure)
This all coupled to :
- .30 over L98
- ZZ4 Camshaft Duration @.050 208/221 Lift: .474/.510 112 LSA
- Hypereutectic flat tops
- 1.5 Gold Crane Roller Rockers
- 1 5/8 Longtube headers
- AFR 180 heads
What you think guys ????
Calderone is offline   Reply With Quote
Old 07-21-2009, 01:46 AM   #2
cumbercr
CF Senior Member
cumbercr's Avatar
That would be a nice combination if you're looking for low end torque. HP will drop off 400-500 RPM higher than the stock TPI. When compared with other intakes, The siamesed runners produce less HP than the super ram, Holley stealth ram or TPiS mini ram due to the length of the runners and resulting lower RPM power band. The trade is that you keep more low end torque. It really comes down to what kind of performance you're looking for.
I'm just guessing, but you could see 400 HP with 425 torque at the crank. There's only one way to know for sure.
cumbercr is offline   Reply With Quote
Old 07-21-2009, 01:56 AM   #3
Calderone
CF Senior Member
Calderone's Avatar
Yes i like the low end torque,i love it
and i want to retain it but i want a little more fun
That's why im thinking about this way 420 would be sweet !
Old 07-21-2009, 01:57 AM   #4
GREGGPENN
CF Senior Member
1989 Chevrolet Corvette
GREGGPENN's Avatar
cumbercr's guess is pretty close.
With a better cam, I predict 400hp/450hp at the crank. You'd need more intake duration to have a chance. The superram cam wouldn't be a bad choice (LPE 219/219). A custom 214/214 wouldn't be recidulous either (if you want a bit more low-end stomp). With 1.5 rockers, XE or XFI lobes would get lift about where the 180's need it.
IIRC, the 3860 is the correct baseplate. The other is for vortec heads.
GREGGPENN is offline   Reply With Quote
Old 07-21-2009, 02:15 AM   #5
Calderone
CF Senior Member
Calderone's Avatar
Thanks for the info Gregg !
#3817 is the vortec tpi
I Still wonder what's the difference between #3860 and #3861
This is what they say :
High-Flo Baseplate Only (1985-92 centerbolt engines) #3860
High-Flo Baseplate Only (aftermarket and early model heads) #3861
I knew i needed to change the cam,but i don't want to pull the motor
What if this baseplates are worked ? can they be ported as well ?
Thanks !
btw...i thought about using a vortec tpi base + vortec heads
but i think the AFR's will be a lot better.-
Old 07-21-2009, 02:42 AM   #6
GREGGPENN
CF Senior Member
GREGGPENN's Avatar
Sorry, the 3861 is for pre-1985 cars w/o EGR. You still want the 3860.
You can port these bases as well. And, you will want to gasket-match it to the SLPs. And, port the living daylights out of the SLPs (with mega-porting/siamesing. Or just use good tubes like TPIS/ASM.
FWIW: If you don't buy the 52mm and AFRs, you could get pretty darn close to the same results with other heads and be able to get your intake now. Vortecs with a Vortec TPI would pull pretty darn good -- probably within 5% of the AFRs.
Old 07-21-2009, 02:51 AM   #7
Calderone
CF Senior Member
Calderone's Avatar
i would have to buy new vortec heads anyway,i won't buy the 52 mm now
my aim is to get tha AFRs asap.-
Now that you say the Vortecs could be close...mmm
i would have to buy vortec heads+base
i guess i will get the AFR's and stick the stock TPI for now
when money allows (maybe next year or maybe sooner) i will collect the parts
for the intake,and yes,super ported SLP's,and all the other elements.
Gregg i want to delete the EGR anyway.-
Yes i think Corvetteplenum.com has some nice SLP's
any experiences with them ?
i think this is the TPI to its limits....is this like the ultimate "tpi looking" build ?
i dont want to lose the tpi look going MR or SR
Old 07-21-2009, 03:30 AM   #8
GREGGPENN
CF Senior Member
GREGGPENN's Avatar
Quote:
Originally Posted by Calderone View Post
Yes i think Corvetteplenum.com has some nice SLP's any experiences with them ?
Short of a FIRST intake it is.
If you don't port and port and port, using a TPIS/ASM runner could work just as well out of the box. SLPs have smaller diameter and need more work.
From pics, I couldn't tell that Corvetteplenum goes down the runner at all. You'll have to ask Mike about that. (BTW: He ports 'em, doesn't sell 'em.)
If not, you can get a bunch removed with a drill-bit extension (1/4" shank) and 1 1/2" wire-wheel + flap wheels. You might also need a burr for your porting -- depending on what you pay others to do.
Honing is another option but costs a bunch. You could hone the runners, and port the base yourself. Much, much easier. Or just buy ASM/TPIS tubes.
Old 07-21-2009, 03:36 AM   #9
Calderone
CF Senior Member
Calderone's Avatar
What about the base ? Edelbrock ported base ?
or should i forget all of this sucky plenums,runners and bases and give a success
amazing shot and put all my effort and invest in the FIRST intake ?????
Would love to know how much HP/TQ is the FIRST capable of !
Old 07-21-2009, 04:18 AM   #10
Calderone
CF Senior Member
Calderone's Avatar
What's the $$ factor
My intake idea v/s First system ?
How much HP/TQ can i lose v/s how much money will save ?
Old 07-21-2009, 06:30 AM   #11
rodj
CF Senior Member
rodj's Avatar
Quote:
GM get 385Hp / 385ft/lb with the Fastburn heads and ZZ4 cam on a 350.
Fastburns are 210cc intake and outflow the AFR 180's over .500.
rodj is offline   Reply With Quote
Old 07-21-2009, 10:14 AM   #12
Calderone
CF Senior Member
Calderone's Avatar
Old 07-21-2009, 10:41 AM   #13
cuisinartvette
CF Senior Member
St. Jude Donor '05
Id put the AFRs on , leave your intake alone for now and save for the FIRST. Your car will make buttloads of torque.
cuisinartvette is online now   Reply With Quote
Old 07-21-2009, 07:46 PM   #14
slamin1
CF Senior Member
slamin1's Avatar
anyone have a link to buy the first intake i cant find the site?
slamin1 is online now   Reply With Quote
Old 07-21-2009, 07:50 PM   #15
Calderone
CF Senior Member
Calderone's Avatar
There you go
http://www.firstfuelinjection.com/products.htm
Im kinda dissapointed im reading this thread :
http://forums.corvetteforum.com/c4-t...rst-tpi-6.html
- I Don't want to change my cam , will my ZZ4 Cam be enough for the FIRST ?
- Badss says that if the car is more street than race...you should use the aftermarket TPI setups (SLP's edelbrock bases ..etc) im confused ....
- i don't want to lose lowrpm torque !
i need to decide
Old 07-21-2009, 07:51 PM   #16
cuisinartvette
CF Senior Member
St. Jude Donor '05
Google
They make a system for LT1s now too.
Old 07-21-2009, 07:56 PM   #17
slamin1
CF Senior Member
slamin1's Avatar
thanks tried to google it but got nothing??????????
but thanks for the link
Old 07-21-2009, 08:02 PM   #18
cuisinartvette
CF Senior Member
St. Jude Donor '05
Calderone with real good heads you dont need a lot of cam, especially since youre after torque. You can upgrade later but I have a feeling you wont feel the need to. TOo many guys cam their TPIs like carbed motors and are sorely dissapointed. Granted yours is a small cam but it will work fine.
Old 07-21-2009, 08:08 PM   #19
Calderone
CF Senior Member
Calderone's Avatar
Yes cuisin,what im trying to do here its a plan.-
Im trying for 2 years to build my engine the way i want
the way i want it to perform (with the help of all of you of course)
this is a neverending project,but i will acomplish it very soon so to speak.-
- im all sold to AFR 180's.- That's a must .-
im looking for the next step.-
and i have 2 choices : The first setup or ...edelbrockbase+ported runners and plenum.-
i want max torque down but ...a bit more of hp.-
i never race the car,but if i do ? i dont want to be in shame !
i already have 2400 holeshot converter ,shift kit and 3.07 gears .-
what to do ?
Old 07-21-2009, 11:56 PM   #20
GREGGPENN
CF Senior Member
GREGGPENN's Avatar
Listen to Cuisinart about the cam. Leaving a small bit of cam on the table while opting for the AFRs is not a bad move. Small cams do extroadinarily well with great heads. Your "ideal" cam may only leave 10-15HP on the table, but your low-end will be as strong as it can get. You'll be as strong as other head options out there -- even with a smaller cam.
I'm curious why you're disappointed after reading the biggest FIRST intake's thread. I don't think there's much to be disappointed about. There are clear measurements inside that thread showing the FIRST provides a good chunk more HP while losing VERY little over the best alternative TPI setups. It's a win-win.
The FIRST will provide the extra HP you want while providing the best low-mid torque possible for street use.
It's a no-brainer.
Reload this Page How much HP / TQ would this combo make ?
Tags
1989, 3861, 66210forum, base, cam, change, corvette, cost, edelbrock, heads, hp, intake, lower, plate, tpi, vortec
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
A 540 Saga Part 2 VETMANIAC C3 Tech/Performance 18 07-13-2005 04:48 PM
E/I Ratio Questions Dougs 90 Engine Mods 26 06-21-2005 12:28 PM
Corvette Parts News! New C6 Section! 8/28/04 CorvettePartsBob Ken's Newsletters 9 10-05-2004 12:23 PM
What would be the best combo for L-48 rebuild AGVI Canadian Events 13 10-01-2003 05:58 PM
TQ > HP vs HP > TQ? MARK's_C5TT C5 Forced Induction/Nitrous 11 11-05-2002 02:35 AM
Camshaft Gurus: Need your opinion! 74vetteman Engine Mods 20 08-23-2002 08:01 PM
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
