Help with 18x11.5 wheels & 335 tires
Alright here's the deal, I'm trying to get a wheel/tire setup like former CF member ROME. Here (green C4 below is his car):
and here's one of many old threads (thanks search!) detailing how he got the wheels to "fit".
http://forums.corvetteforum.com/c4-t...-fit-a-c4.html
Jon @ CCW was able to find Rome's old build sheet and spec'd my wheels the same per my request. I've (like Rome) purchased new trailing arms, swaybar end links, but that's not the problem. My problems are (1) my wheels don't fit like his and I'm not sure why? (2) If I get the wheels fixed, I can't see how they won't be touching the sway bar!?!?....basically I don't see how you can get these size wheel/tire tucked under the rear fender, and NOT have it touching the swaybar
need better pics, but you get the idea...
My rear wheels are spec'd at 18x11.5 with 8.25 BS
Any help would be appreciated. Thanks!
lt4power- the pictures of Romes car look to be significantly lower (his vette has been lowered).
I think he might have played with the alignment slightly as well as lowering the car quite a bit.
How does the "other" side of your c4 look? I know you're aware of the fact that these c4's tend to have a slightly off center differential (common problem, but not ALL c4's).
edit
if one side is further out than the other, a body shop with be able to correct that. there was another member on this forum (red corvette) how had a significant difference from passenger side to driver side. It cost him $500~ some odd dollars to have it correct at a shop that knew what they were doing (not all shops can do the job, find a shop with a lot of corvette experience).
edit
edit
edit
hmmm...I don't remember anything being different from side-to-side, but I'll go re-check. I'm not sure how alignment could make more swaybar room? I'll go lower it, and take some more pics and report back....
A link!
Here's a link where "Rome" mentions some "modified" swaybars and control arms. I recall where some had actually installed the early C4 knucles, brakes etc to acquire substantially more room for the "fatter tire". There's a link he's posted that when applied goes to a lost page! I'm quite sure there's substantially more to the fitment than you anticipated!
http://forums.corvetteforum.com/c4-t...ce-update.html
[IMG][/IMG]
[IMG][/IMG]
Also, I don't think his '89 with a newer C4 body would spec any different...
I also think that if you work the lowering screws a bit, it will "tuck" in the wheel/tire combo a bit more (as the suspension geometry works on an arch - through the suspensions travel).
Finally, EM does (or at least did-to my knowledge) offer a kit that allowed c4 owners to run wider wheels/tires (like your 335's). I am not even sure what was included in the kit, or what it cost, but give Merle a call and see if he's got any advice for you?
As mentioned before, measure how far out each side sticks out to determine if the car has an alignment issue with the differential (this is a common problem with c4's). I am just curious to know if it sticks this far out on "just" the driver side.
looks significantly better than before though, you're not really "that" far off. It might just take some minor tweaking (i.e. a good alignment shop should get those in spec, and tucked in nicely).
*****Rome's car is still slightly lower than what you're is sitting at right now **********
I think it is the different year with his conversion rear, there is probably enough to make the difference you see. I know Jon has made the 11.5 for a number of C4's and I have talked to him about this in the past and he said they would tuck in, I would of gone with his suggested specs for the 96 as opposed to Rome's. Could be completely wrong but that is my guess. What did Jon say? I remember reading ROMES post in the past, but I know I have seen others with 11.5 CCW's and they did not have to do any mods to fit.
I believe to accomplish what you've set out to do you need to just revert to early '87 and earlier knuckles, spindles, brakes and control arms. Your half shafts, rear spring etc will all still work. That would get you something near 13mm (1/2") per side.
Here's an easy way to get the information you desire!! Here's a Craigs List posting wanting to sell his adjustable arms BECAUSE his rear is "narrowed"!!! Maybe he'll share the information! I'd say he's "been" where you want to go and "done" what you want to do!!
http://honolulu.craigslist.org/oah/pts/1268722423.html
BTW - I didn't use his post to come up with the dimension I mentioned in the first paragraph. That's from some dimensions a friend used from an early vs late suspension for a street rod project. His mention does seem to confirm my thoughts.
I don't think that he ever indicated that, and I've read his various posting regarding this several times...but I've been thinking this might be possible. Maybe that is one of the several mods that was done to his car before he purchased it....I remember it having some mods when he got it.
when changing to the early knuckles you will need these 2 spacers to take the slack up on the late brake bracket and the spindle. if they are not used the early spindle will not tighten up and the space between the early knuckle and late brack bracket can twist and cause all kinds of hell.
