Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-09-2009, 10:44 PM   #1
bfrancesca
Junior Member
Default stalls when warms up
I have a 1990 that stalls when it warms up, it seems like it is out of fuel the car will crank but no start you let it cool down for a couple of hours and it will restart no problem. I have changed fuel filter and checked ECM codes and it has none, does anyone have any suggestions
bfrancesca is offline   Reply With Quote
Old 07-09-2009, 10:49 PM   #2
FICINJECTORS
Supporting Vendor
FICINJECTORS's Avatar
Quote:
get an ohm meter and check each injector coil when hot.. They should be 16ohms// report your test back here
FICINJECTORS is online now   Reply With Quote
Old 07-10-2009, 09:48 AM   #3
WW7
CF Senior Member
WW7's Avatar
Ignition control modules also do this when they are going bad. Check your injectors first like Jon says,if they are ok it may be the ICM, a lot of times when they heat up they quite, when they cool down they work..WW
WW7 is offline   Reply With Quote
Old 07-10-2009, 05:21 PM   #4
bfrancesca
Junior Member
I ohmed all injestors hot and cold
Hot Cold
16.7 16.4
16.8 16.3
1.6 9.6
16.9 16.4
17.2 16.3
16.0 16.3
16.9 16.4
2.4 12.4
Looks like I have 2 bad fuel injectors
Old 07-10-2009, 07:24 PM   #5
FICINJECTORS
Supporting Vendor
Hot Cold
16.7 16.4
16.8 16.3
1.6 9.6
16.9 16.4
17.2 16.3
16.0 16.3
16.9 16.4
2.4 12.4
yup,, call me I am always on my cell after hours 770 842 0882
Reload this Page stalls when warms up
Tags
1990, 90, corvette, heating, hot, stall, stalls, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rough Idle after procharger install...Please help. Scott94C4 C4 Forced Induction/Nitrous 9 01-10-2004 09:39 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
