Exhaust manifold replacement
Ive had my automatic 94 vette for almost a year now and am almost done fixing everything thats wrong with it. I have been able to find most things searching but this one has me stumped which has lead me to write create my first thread. I have a small exhaust leak coming from the rear driver side exhaust manifold. Not sure exactly where all i know is its inside the heat shield and on a cold day can see it puffing up from there. The manifold is stock and looks rusted to hell so im guessing its cracked. Ive been looking for an exhaust manifold as all im doing right now is restoring it to its original condition and enjoying it like that before deciding what to do with it. I have not been able to find a stock replacement that isn't used and rusted (if im gonna put a new part in might as well be new and last). Any recommendations as to what would fit without having to do any or very minimal modifications. working with very basic tools here and not trying to break the bank or increase performance, just get something that will fit and let her run like she used to. I did find these from Pacesetter https://www.newlevelmotorsports.com/...w=papehe19chco would these do the trick? any other recommendations around the same preicpoint? I really dont want to put a 80-100 dollar used ebay manifold on it.
In terms of "easy" nothing is going to be easier than replacing the stock manifold with another one. Every header install always, without fail, requires some fabrication and cussing. For example, you will need to make up some spacers in order to retain the braces which run from the third bolt back which provide needed stiffening for the cast aluminum accessory bracket. the shorties won't add any real power, and unless you get them coated they will look like crap in a week.
Pretty rare for an LT1 manifold to crack. Probably just the gasket?
Matt94 (05-13-2020)
Where are you in MN? I'm just over the border near Hudson. I have a set of manifolds that I pulled that I'd be willing to let you have (I was just going to scrap them) as long as we could just meet to hand them to you. I really don't want to deal with shipping, they are heavy.
They're yours if you want them. Honestly, I'd feel bad chucking them if someone else can use them.
I work in St Paul, so I could bring them with me (or give them to the guy that has the Minneapolis area) when you're ready for them.
I'll just set them aside for now.
